Old 04-11-2017, 03:21 PM   #15
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Originally Posted by mr_squirrel View Post
No issues with knock or anything? Still relatively new to tunes and how cats affect flow. Wondering about using the stage 2 uel catless tune with a chatted header.
Sent from my ONEPLUS A3000 using Tapatalk
I've been running the stage 2 UEL 93 catless header tune (older version of the tune if it matters and AT) since winter started with my catted FT86 speedfactory header. I've had some very small FLKC like -.65 but that is usually when going full throttle at low RPM in 5th or 6th gear. I also don't think I've seen my IAM ever get below .88
Take it with a grain of salt and make sure you log on your own vehicle but I haven't had any problems with it and I have my OFT setup where it is mounted and I can see it while driving.
@shiv are the ft86sf catted header tunes available on the downloads page on open flash's site? I don't see them listed but maybe they are just in the regular OTS files?
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 04-11-2017, 03:25 PM   #16
STV3
Señor Member
STV3's Avatar
Yeah I've been running that tune too with my FT86SF catted UEL header. Had no clue they had a tune for it.
STV3 is offline   Reply With Quote
Old 04-11-2017, 03:42 PM   #17
DarkSunrise
DarkSunrise's Avatar
Originally Posted by frs_caskey View Post
what kind of sound are you getting from your jdl catted uel header? does it sound same as stock? or are you getting a nice uel rumble from it?
FWIW I recently switched to a FT86SF catted UEL and lost a lot of that rumble. I could hear it a lot more with my previous setup (JDL catless UEL + aftermarket OP/FP).
2022 BRZ Build
2013 FR-S Build
Old 04-11-2017, 04:25 PM   #18
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
With my catted JDL UEL I get rumble in the lower RPMs but it smooths out in the higher RPMs sooner than a catless header from what I can tell from Youtube videos.
I'm also running the Stage 2 UEL tune with mine and I had just a couple places where I had to pull about .5 degrees of timing, but the most FLKC I see now is -.65 and my IAM stays at 1 unless I plant my foot in a high gear at low RPMs (which obviously you don't need to do)
In an earlier post somewhere on the forum Shiv said the tune for the FT86SF catted header would be the new Stage 2, and there would be a Stage 2+ for catless headers. So I would imagine it will run just as well for catted headers as the Stage 2 now currently does
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 04-11-2017, 05:00 PM   #19
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Now that you mention it, I remember seeing that at some point also, the 2 vs 2+. I should probably update my tunes anyway since mine are at least a year old at this point. Maybe I'll finally get around to the cold start corrections too.......
Old 04-11-2017, 07:10 PM   #20
frs_caskey
frs_caskey's Avatar
Drives: 2013 FRS DGM.
so there is a new stage 2 for catted headers? and a new 2+ for catless??
frs_caskey is offline   Reply With Quote
Old 04-11-2017, 07:23 PM   #21
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
right now OFT's site shows just the OTS tunes and OFH optimized ones. OTS tunes were last update 3/30/16
http://www.openflashtablet.com/downloads/
I emailed shiv after work today and i'll post what he says about these tunes or where to find the speedfactory ones.
Old 04-11-2017, 08:33 PM   #22
BFIFE22
BFIFE22's Avatar
He said when the V.3 OTS Tunes were released there would be a Stage 2 and Stage2+. The Stage 2 was going to be the tune he did for the FT86SF catted header, and the Stage 2+ would be for the OpenFlash Catless Header. Not sure which one someone with a catless header that isn't an OF brand would be better to use, but at least we will know that the Stage 2 was done with a catted header in mind. The V.3 Tunes haven't been released yet though
Old 04-11-2017, 08:47 PM   #23
frs_caskey
frs_caskey's Avatar
He said when the V.3 OTS Tunes were released there would be a Stage 2 and Stage2+. The Stage 2 was going to be the tune he did for the FT86SF catted header, and the Stage 2+ would be for the OpenFlash Catless Header. Not sure which one someone with a catless header that isn't an OF brand would be better to use, but at least we will no that the Stage 2 was done with a catted header in mind. The V.3 Tunes haven't been released yet though
when will the v.3 tunes be released? also if stage 2+ would be for cattless OFH but everyone is using it for all cattless headers then the 2 would work for any catted header?? because i think i want to go with the JDl catted header over the FT86SF catted header. but i want to make sure the JDL catted will get as much help from the tune as the FT86SF catted will get.
Old 04-11-2017, 10:35 PM   #24
steve99
want a uel catted header because i dont want my exhaust stupid loud, but i want the uel rumble.
It wont be stupid loud if you keep the stock front pipe with secondary cat in it. And if you want super quiet just keep the stock catback as well. else get something like invidia Q300 or similar
Catless header will be more efficient and cheaper.
Old 04-11-2017, 10:51 PM   #25
frs_caskey
frs_caskey's Avatar
im going with a catted header because i already have the mxp comp rs exhaust. its a pretty loud catback by itself and i feel once paired with a cattless uel it will be much louder. unless im mistaken on how much louder a cattless header will make it.
Old 04-17-2017, 06:54 PM   #26
G-awesome
Drives: 2015 Firestorm Scion FRS
don't think there's a set date for the v.3 tunes so we folks will have to wait patiently...
I'm itching to get my hands on the official catted header tune to see how much better it runs than my amateur stage 1/2 frankentune
G-awesome is offline   Reply With Quote
Old 04-17-2017, 09:42 PM   #27
Carbinebbq
Carbinebbq's Avatar
Drives: 2017 BRZ Limited
Lol is frankentune your name for the beta? 😁😅
Instagram @Blue.icee.brz
Carbinebbq is offline   Reply With Quote
Old 04-20-2017, 02:46 PM   #28
Glaedon
Drives: 2013 Subaru BRZ
Hey all, just a quick update.
I shot Shiv and email about the catted header tune. He got back to me promptly and we worked it out to have him email me a Stg2 Catted UEL tune. I just flashed on Tuesday and so far - so good. If you really want the tune you may want to shoot Shiv an email.
Glaedon is offline   Reply With Quote
jdl catted header OTS tune ok? deuncos Software Tuning 43 06-13-2018 02:34 PM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
Catted Header or Stage 1 Tune first? Mr.Impreza Engine, Exhaust, Transmission 12 09-04-2015 05:35 PM
Catted header or catted front pipe? wilfredwong Engine, Exhaust, Transmission 5 02-09-2015 06:11 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
