| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: 17 Asphalt 86
Installed Cusco bushings in the driveway yesterday. Can confirm they are longer than factory outers. You could potentially trim the factory inners to slide them back in, but I wasn't willing to fiddle with it while under the car.
For anyone installing a stiffer rear bushing at the same time, take advantage of the extra space when you lift the front of the carrier. I found it much easier to get a few extra inches of space which helps immensely if you are doing this on jack stands in the driveway. |
| Cam Carrier Oil Leak (hole in the cam carrier) | Subaru86 | Issues | Warranty | Recalls / TSB | 0 | 02-22-2017 02:50 PM |
| TWM Front Carrier Bushing... | Ty89m | Engine, Exhaust, Transmission | 15 | 10-10-2015 01:09 PM |
| Shifter springs/bushings/shifter performance | Darnold | Engine, Exhaust, Transmission | 10 | 10-23-2014 12:49 AM |
| Replace shifter bushings? | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 03-31-2013 11:49 AM |
| *NEW* Scion FR-S Front and Rear Carrier/Stay Bushings | TWM Performance | TWMPerformance | Transmission and Driveline | 0 | 02-25-2013 06:31 PM |
