Old 07-17-2012, 07:43 PM   #15
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by MrBodyMassage View Post
I've seen many on here recommending your first oil change at 1,000. I'm of the opinion that you should wait til 3,500-5,000 miles to do your first change. Here's why: The factory fill is 0w20 synthetic, so it's not dino oil. There may very well be small metallic shavings from break-in, but those all should be caught by the oil filter. The main reason to leave it in the recommended interval is this:
The above is an oil analysis done of a factory fill from a FB25 in a 2011 Subaru Forester. It was taken from http://www.bobistheoilguy.com/forums...Number=2251431.
What do these numbers mean? Basically the Moly, Zinc, and Phosphorus are higher than normal oils. This seems to be part of a stronger additives package put in to the factory fill.
Is this being super anal? Sure it is. That's why we're all on this website, specifically in this subforum
If you changed at 1,000 miles will you ever notice a difference? Probably not. I just posted this as food for thought.
Ha, where was this post when I was trying to tell a guy on here a few months back about all of the above info., and he thought he knew better?
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
Oil change after break in? oops86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 08-03-2012 12:09 AM
oil change question jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-19-2012 06:14 PM
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
