Old 03-11-2017, 04:07 PM   #15
Recoil6
Drives: Subaru BRZ
Hi Chimera,
Did you do the entire interior or just the doors? Would you say that it was worth the money?
Recoil6 is offline   Reply With Quote
Old 03-12-2017, 07:35 AM   #16
Chimera
Drives: FRS
Originally Posted by Recoil6 View Post
Hi Chimera,
I did the doors, it helps, but I didn't go to crazy with the stuff. I did use the speaker tweakers. They helped. Other spots I did that helped was in the rear over the wheel I used some that helped with road noise, and in the rear deck around the spot welds helped immensely with creaking sounds when turning... My understanding is that is a MY13 quirk and that later years have less issues with that.
Old 03-15-2017, 11:02 AM   #17
Recoil6
Drives: Subaru BRZ
Those are the spots that I was thinking of doing, I didn't thought of doing the back of the HU tho, I will look into that one. Thank you!
Old 03-15-2017, 11:05 AM   #18
Chimera
Drives: FRS
Rear deck, as in behind the back seats, over the trunk area. Mine made a lot of creaking noises when turning before I applied some sound deadening strips to the spot welds. crawl into the trunk from the front and look up you'll see what im talking about.. I think the MY13s had it the worse.. my understanding was there was TSB, and later they added Oil Lube and some foam to the area. haven't looked at another one that closely myself though so im not 100% on that
Old 03-15-2017, 02:29 PM   #19
NickB34
Drives: 2014 BRZ
I used the cheap stuff, and it went on great. Huge improvement on the doors, no more door switch rattle. I also put some on rear wheel wells and the trunk. Worth it in my opinion if you have it all torn apart.
https://www.amazon.com/Noico-deadeni...s=noico+80+mil
NickB34 is offline   Reply With Quote
Old 03-15-2017, 08:45 PM   #20
Recoil6
Drives: Subaru BRZ
Ah I see what you mean now Chimera, I will check mine, with that said I do not hear any cracking when I am turning.
NickB34, you are right since I am going to tear apart the back and the doors might as well put some deadener in there.
I am going to go with multiple approaches, I am doing the CLD Tiles, neoprene and MLV.
I order the MLV today, I need to shop around for the neoprene and the CLD tiles are out of stock right now. Hopefully I can work on this early next month.
Old 03-15-2017, 09:12 PM   #21
NickB34
Drives: 2014 BRZ
Sounds proper, I just don't have the patience to go all out with that stuff. It's a ton of work for minor gains.
Did you decide on the PP-3 way? I'll be waiting for a review on those.
Sent from my SAMSUNG-SM-N920A using Tapatalk
amp, component speakers, ddx916ws
DDX916WS in 2013 BRZ Naeblis Electronics | Audio | NAV | Infotainment 11 04-11-2018 12:31 AM
Anyone have Focal Access 165 A3 3-Way Component Speakers? Project86 Electronics | Audio | NAV | Infotainment 1 07-24-2014 07:32 PM
Thoughts on component speakers? Griever423 Electronics | Audio | NAV | Infotainment 10 06-30-2014 08:52 PM
Lets Talk Component Speakers Skippman Electronics | Audio | NAV | Infotainment 34 01-09-2014 01:29 PM
Replaced front speakers with component set - sound is worse AlexTheGreek Electronics | Audio | NAV | Infotainment 37 04-15-2013 09:58 PM
