#15 |
Regarding the piping sizes, I measured both headers and they are the external ones.
#16 |
Take a hammer and chisel to the cat in the header, then have a good tuner tune the car.
The dip isn't really the issue people make out. Marketing has turned it into something to make money. I tried Tomei headers, the decated OWM header beat them hands down. No sticker or street cred though, only more power for no extra dollars. Did I say use a "good" tuner..... In the end a AVO turbo is what you want.. Have a look at me sig, the ending is sad though. Do a skid...
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#18 | |
#19 | |
Drives: '15 BRZ RA
Attached the details of the new header. There was an increase in the pipe diameters. The diameter change is 5% and 8% respectively. In fact, if you do the math, the actual area increase is even more! In the range of 11% and 16.5% ... Only problem, is that the torque dip is worse. This makes total sense if you increase the pipes. They tried to hide this a bit with the red intake manifold and the 4.3 differential change. Last edited by nikitopo; 05-13-2020 at 04:31 AM. |
#20 | |
#21 |
Drives: brz 2017 hksv2
because you have high EGT even on NA, and with forced induction you increase it even more and with a cat and supercharger you can possibly reach 1000 degrees Celsius in particular condition and risk of medium term damage to the cat
and that would also be dangerous to engine if cat falls apart |
#22 |
Drives: '15 BRZ RA
Cat will fail soon with a s/c. These are the things vendors will not say often. Meaning that you 'll need to go with a catless header, because it'll increase the overall s/c cost.
#23 |
LMGTFY
Drives: 13 FRS, 91 Miata
So all those S/C kits that are CARB legal will destroy cats thus making the kit no longer CARB legal???
Sounds legit. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Danny318 (11-14-2020) |
#24 | |
Weight Weenie
Drives: 15 FR-S
That's a lot of changes and money to end up back where you started. |
#25 | |
2013 Series 10 FRS #553
#26 | |
LMGTFY
Which is very misleading. |
| WTB: 2017 BRZ Stock Wheels | brzsubarusti13 | Want-To-Buy Requests | 4 | 10-26-2016 04:50 PM |
| WTB 2017 86 Stock Wheels | Slade | Want-To-Buy Requests | 0 | 09-30-2016 10:17 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
