Old 02-20-2017, 08:32 PM   #1
Bobster
Drives: GT86 GTS
2017 Stock Header
Hi
Anyone got any photos of the 2017 stock headers and diameters of the new piping?
Thanks for help.
Bob
Bobster is offline   Reply With Quote
Old 02-21-2017, 07:57 AM   #2
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
My PDF that can be found with a google search states:
Upper branch diameter with 4 callouts 42.7mm to 45mm
Upper branch diameter with 2 callsouts 45mm to 48.6mm
illmatic is offline   Reply With Quote
Old 02-21-2017, 08:57 PM   #3
Bobster
Drives: GT86 GTS
Thanks, I am thinking about one of these for a quiet SC build
Old 02-21-2017, 09:00 PM   #4
Somerandom18
Drives: 2017 manual BRZ
I have a almost completely stock system on my 2017. Only difference in a catless unresonated front pipe. It sounds really nice in the cabin and is still quiet outside.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 02-21-2017, 09:55 PM   #5
steve99
just get a catless header and keep the stock catback ?
not sure how long stock cat in header will last with turbo or SC setups.
Old 02-22-2017, 12:01 AM   #6
BRZ FTW
Drives: 2017 Subaru BRZ
Any noticeable changes in power?
BRZ FTW is offline   Reply With Quote
Old 02-22-2017, 12:11 AM   #7
johan
Drives: '14 981CS, '99 NB1
^this
It's not wise to leave a close coupled cat in place with a supercharger. Just swap that out and leave the overpipe, front pipe, catback stock. I have my 2017 with a Tomei and Harrop SC and aside from the cold start, it sounds almost as quiet as stock - even with the blower.
johan is offline   Reply With Quote
Old 02-22-2017, 02:00 AM   #8
Bobster
Drives: GT86 GTS
I have an Invidia R400 that I want to keep, maybe try stock FP
Old 02-22-2017, 06:53 AM   #9
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
however, if you do want a 17 header from my recent PP BRZ let me know. It has just at 500 miles on it, and its sitting on my workbench. I just installed an ACE 350 header this weekend. So OEM 17 header is available.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 02-23-2017, 08:59 AM   #10
stevesnj
stevesnj's Avatar
3mm seems a nice size increase, inch conversion for us non metric Americans. Is it worth switching over to the 2017? I want it to make a difference, maybe faster revs?
Upper branch diameter with 4 callouts 42.7mm(1-11/16") to 45mm (1-3/4")
Upper branch diameter with 2 callouts 45mm (1-3/4")to 48.6mm(1-15/16")
My 2016 Build thread
Old 02-23-2017, 04:14 PM   #11
Bobster
Drives: GT86 GTS
For NA purposes your really need to ditch the cat to get the performance but I some benefits for a supercharged setup, especially if you want to clear emissions as well
Old 05-08-2017, 02:27 PM   #12
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Originally Posted by johan View Post
^this
Why is it not wise? I've seen a few threads on here showing little to no gains between stock and aftermarket headers on a supercharged FA20.
I can tell you that my HKS EL catless header with the stock FP is noticeably louder. I have the Vortech SC installed and I'm seriously considering going back to the stock header to make it quieter.
To be fair I have the RS1 quad tip exhaust which was pretty loud even with the stock header.
avishenoy1 is offline   Reply With Quote
Old 05-12-2020, 02:34 AM   #13
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Thread revival
Wanted to harbor some thoughts from you guys. I've recently been looking at a Tomei EL header for my 2017+ brz which has the updated header from factory. According to this thread, the new oem design has larger pipe diameter (per post #2) starting from 45mm to 48.6mm. The Tomei is only 42.7mm to 45mm, which would be smaller than oem. The only advantage of the Tomei would be the removal of the cat.
Would that mean stock headers would potentially have better performance, sound aside.
ItsReiko is offline   Reply With Quote
Old 05-12-2020, 03:19 AM   #14
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by ItsReiko View Post
Thread revival
I've went from a HKS header 42.7/50.8/60 to a MY17 catted and decatted back to a HKS. The torque dip from the OEM header is huge even after punching out the cat. If you are want to run EL for around $600 if you look around, I'd go HKS.
PulsarBeeerz is offline   Reply With Quote
WTB: 2017 BRZ Stock Wheels brzsubarusti13 Want-To-Buy Requests 4 10-26-2016 03:50 PM
WTB 2017 86 Stock Wheels Slade Want-To-Buy Requests 0 09-30-2016 09:17 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
