Old 02-16-2017, 10:18 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Flame9020 View Post
Update: The car is "fixed", apparently the shift linkage was messed up but now the whole shifter feels loose and sloppy. Also I am able to rotate the entire shifter about an 8th of a full rotation. The mechanic claims this isn't an issue but I am skeptical.
Originally Posted by gramicci101 View Post
You should be skeptical; that doesn't sound right. It sounds like a bushing wasn't reinstalled somewhere.
Curse of the TuRD short shift adapter. Either installed without bushings or it came loose. Did you have at least a day where the lever was tight and you could not rotate it? If so, it came loose. If not, it was installed without bushings.
Old 02-18-2017, 03:28 PM   #16
Flame9020
Drives: 2015 Scion FR-S
It was always tight until it went in for this last round of "repair". I'm tempted to ask them to take the TRD adapter out because I never wanted it and it's only been a pain.
Flame9020 is offline   Reply With Quote
Old 02-18-2017, 04:42 PM   #17
Ultramaroon
not playing cards
Do it. Don't look back.
shifter issue srgssgtmatt Issues | Warranty | Recalls / TSB 5 09-15-2016 03:01 PM
Short shifter clearance issue with driveshaft Gank61 Engine, Exhaust, Transmission 16 03-08-2016 07:48 AM
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 10:36 AM
shifter issue? abutterman Issues | Warranty | Recalls / TSB 54 02-26-2014 06:10 PM
Issue with Kartboy short shifter tisb0b Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 10-20-2013 07:15 AM
