#15 | |
| The Following User Says Thank You to Riftur For This Useful Post: | Tcoat (02-01-2017) |
#16 |
Hmmmm. Did you have your heater on?
#17 |
#18 |
The compressor comes on with the heater on these cars if set to windshield. It dries the air for defrost.
#20 |
OK I am baffled and have run out of suggestions.
#21 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
Everything is working fine - All the switches and relays work, but the circuit that grounds via ECM pin 26 is closed before all the other circuits close. That is all... Theoretically, you shouldn't be able to turn the key fast enough to "beat" the relays, unless something is sticky or the initial voltage just isn't quite there... But you can simulate the condition in an MT car by leaving the clutch out... Hold the key to start, then press the clutch. You just completed the circuit, but nothing happens, because the ECU won't complete the ground for pin 26... Because reasons... And some internal start logic that I'm not privy to... BUT, if you do the same thing in the car on the right side of the diagram, the car starts as soon as the clutch hits the switch. The only difference between these two is that one relay circuit terminates at a plain old ground, and the other disappears into a "logic box." Here are two starter circuits to illustrate my point. FRS, and an older car.
There are many ways to displace.
-Spartarus |
#22 |
......and an even older starter circuit .....
![]() humfrz |
#23 |
Ok the car is still starting on the first try for the 2nd day. As far as the car feeling like it might stall when coming to a stop, it was doing it yesterday on the drive home. This morning everything was fine though. I did need to add gas this morning so i am wondering if the last tank of gas could have caused the issue of stuttering when stopping. I usually always put Chevron 93 in my car but will use shell 93 also. Last fill up was shell. Think it could have made a difference? Gonna keep running the car in sport mode to see if it does it again.
#24 |
I am an IT tech by trade and really hate when I cant duplicate something. It drives me nutz!
| cranking noise when steering? | dad&sonFRS | Issues | Warranty | Recalls / TSB | 27 | 06-10-2019 08:04 PM |
| CELs and not cranking | 86 driver | Issues | Warranty | Recalls / TSB | 8 | 09-28-2017 01:08 PM |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
| Ethanol Vs Gas Cranking | Luckrider | Software Tuning | 2 | 01-25-2014 08:44 PM |
