Old 01-19-2017, 07:17 PM   #15
steve99
Originally Posted by aagun View Post
dc the 103
do i have to connect it to 5v ?
Ok if you can measure the voltage on the desolxered pin 103 and it is near 5v then no need to make connection
Old 01-20-2017, 04:25 AM   #16
aagun
Drives: 86
https://dl.dropboxusercontent.com/co...qZXxHsVEx/file
here where i cut
aagun is offline   Reply With Quote
Old 01-20-2017, 06:22 AM   #17
steve99
I cannot access file maybe i dont have permission
If you can jist lift pin 103 slightly this should be enough maybe use smal blade to apply some pressure then a little heat from very small soldering iron
Old 01-20-2017, 06:28 AM   #18
aagun
Drives: 86
i cant solder microcontroller . it is soo same i cut the link . as above
Old 01-20-2017, 09:07 AM   #19
aagun
Drives: 86
strange
103 = 0v cuted
97 = 3v -+5
103 target = 3v before cut line
Old 01-20-2017, 11:40 AM   #20
aagun
Drives: 86
there are PLLVcc = 3.3v in 95 pin
95 connect to 96 + 94 dirct
94 = MDC
96 = MDD
Old 01-20-2017, 11:43 AM   #21
aagun
Drives: 86
@steve99
MDA = 3.3V
MDB = 3.3V
IS THAT MEAN MDA = 1 + MDB = 1 AND IT IN UBM ??
Old 01-20-2017, 01:47 PM   #22
aagun
Drives: 86
giveup
Old 01-20-2017, 02:20 PM   #23
g0lds
Drives: 14 BRZ Limited
Do you have any salvage yards around you that could source you a used ECU? Used ECUs in USA run about $50-$100...
g0lds is offline   Reply With Quote
The Following User Says Thank You to g0lds For This Useful Post:
aagun (01-20-2017)
Old 01-20-2017, 02:40 PM   #24
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Here's one for $50 before international shipping.
http://www.ebay.com/itm/2013-Scion-F...RYXHvx&vxp=mtr
The Following User Says Thank You to EAGLE5 For This Useful Post:
aagun (01-20-2017)
Old 01-20-2017, 05:49 PM   #25
steve99
@steve99
MDA = 3.3V
MDB = 3.3V
Yes that should give user boot mode
aagun (01-20-2017)
Old 01-20-2017, 07:33 PM   #26
aagun
Drives: 86
not working
Old 01-20-2017, 08:23 PM   #27
steve99
not working
Ok it was worth a try
Only option now is replacement ecu
Unless someone works out how to read the boot area 00000 7ffff
Hopefully you can get a cheap secondhand ecu
aagun (01-21-2017)
Old 01-21-2017, 03:12 AM   #28
EAGLE5
Dismember
EAGLE5's Avatar
Automatic or manual transmission? The link I posted is manual, I think.
Bricked ECU? FirestormFlex Software Tuning 8 03-14-2016 10:20 AM
My OFT is basically bricked austin_ellas Software Tuning 19 03-08-2016 07:59 PM
Who has Bricked an ECU Toyota John Software Tuning 5 03-02-2015 11:10 PM
Need Bricked BRZ 86 ECU steve99 Software Tuning 0 10-25-2014 07:09 PM
I think I bricked my ECU with EcuTek help iketiak Engine, Exhaust, Transmission 4 07-04-2013 12:19 AM
