Old 01-16-2017, 09:42 AM   #15
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
These cars are so small that I am sloppy as hell when I park. I pull up 2' off the parking block, I'm a little slanted and I'm still all the way in the spot in most places. Remember, you're in a matchbox, you don't have to park perfectly
The Following User Says Thank You to guybo For This Useful Post:
Overdrive (01-16-2017)
Old 01-16-2017, 02:15 PM   #16
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Very true. It took me about two weeks to adjust to having a lot less real estate in front of and behind me. I had a few horrible parking jobs during that time, but I've got it down pretty well now. Plus, like you said, you don't have to pull up to the end of the space and you have a ton of clearance in either direction. I'm always well clear of those bump curbs and my rear end is easily 2-3 feet in from the back of the space.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-16-2017, 04:13 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, rear of ours IS higher. One can use that to advantage when parking over curb, or if parking with "wheel till curb". With one exception, if mudflaps like rallyarmor's are used. Backing up to kerb with those may break them off.
AND given all that daily driving experience of course i see even less any need to lower our already low at stock cars even further reducing that clearance & shock travel.
Old 01-16-2017, 04:19 PM   #18
Icecreamtruk
Drives: Track preped NA FRS
Two exceptions: rear diffusers (real ones, not the plastic crap they sell you at the dealer).
Old 01-16-2017, 04:22 PM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
Icecreamtruk: including on unlowered car & with ones like Velox's street one with not as aggressively high & long fins?
Old 01-16-2017, 04:49 PM   #20
Icecreamtruk
Yes including that one. It still takes a good 1" to 2" from your height on the rear, and remember altho the diffuser is close to the bumper on its back section, its much closer to the ground where the axleback goes under it.
Parking at LGA - Parking Spot or Park Plus Marriott WRXcellent NY / NJ / CT / PA 5 01-21-2016 05:43 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 02:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 06:21 PM
Need a reality check - scraped underside of bumper on parking block 1Cor10:23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-24-2014 01:01 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 07:48 AM
