Old 01-10-2017, 11:49 PM   #1
Jeebz
Drives: 2016 Frs
Went over parking block
Hi Guys, my stupid self drives over a parking block and it looks like I dented my exhaust front pipe or header. Is this really bad? I think I have to take it to the dealership tomorrow....
http://imgur.com/a/JxXjV
Jeebz is offline   Reply With Quote
Old 01-11-2017, 12:01 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Thats just the heatshield over the front pipe. Its probably fine.
Your header is in front of the oil pan behind the metal skid plate. If that really is dented I'd be more worried about possible damage to the oil pan
zeal86 (01-11-2017)
Old 01-11-2017, 12:14 AM   #3
Jeebz
Drives: 2016 Frs
Thanks Finch, that will make me sleep a little better tonight. I will bring it in just in case, and also worried about the oil pan.
Old 01-11-2017, 01:00 AM   #4
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Drop the skid plate and have a look at what it's been protecting. Otherwise you just made the skid plate do its job. Might need to replace it if it can't go back to normal shape, but that's better than wrecking your pan or any of the exhaust plumbing.
EDIT: Totally missed the fact that you posted a picture, and thought you were saying you dented the skid plate. I really don't think you did anything terrible. Denting the shield isn't the end of the world, and it doesn't look that bad as far as the dent. The scrape looks ugly, but that's all it really is, ugly looking. Can't hurt to have the dealer look at stuff just to make sure, but don't let them try to railroad you into a bunch of unnecessary hardware replacement.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
humfrz (01-11-2017)
Old 01-11-2017, 02:12 AM   #5
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
If it's still running the same and there are no leaks I'd just keep an eye on it and leave it.
Take it to a dealer minor damage like this and your wallet will get raped.
Scrappydoo is offline   Reply With Quote
The Following 2 Users Say Thank You to Scrappydoo For This Useful Post:
Tcoat (01-16-2017), Ultramaroon (01-12-2017)
Old 01-11-2017, 02:30 AM   #6
SubieRumble
RWD Snob
SubieRumble's Avatar
Drives: 2014 Ultramarine FRS MT
Looks fine to me.
Slow car fast. > Fast car slow.
SubieRumble is offline   Reply With Quote
Old 01-11-2017, 02:51 AM   #7
humfrz
That was dumb ........you're supposed to STOP when you hear the front lip go schhuureeenchhhhh.
Then all you have to worry about is backing up ....... and leaving the front lip in parking lot ......
But NOOOOO ....... you just kept on going ...... thinking you could clear the obstacle ......
I suggest you take your car into the dealer and trade it for a Jeep.
(ol humfrz is jest ah messen wich ya .... )
Seriously, it doesn't look like anything except the heat shield was scuffed up.
Be advised, that not all parking stops are created equal ...... some are taller than others and some have these "barbs" of re-bar that stick up to "hook" your front lip and ...... rip it off.
I know, because I have 3 nasty scars under my car's front lip ........
humfrz
Old 01-11-2017, 10:58 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's totaled, sell car, buy a Honda. It might blow your balls off when you least expect it.
The Following User Says Thank You to Mr.ac For This Useful Post:
tigermack (01-14-2017)
Old 01-12-2017, 05:35 AM   #9
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Just the heat shield for the secondary cat. Don't worry, you did no damage of any sort.
Old 01-13-2017, 11:34 PM   #10
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Dude you good dw about it if you see a crack than maybe you should bring to toyota
turtlefeeder is offline   Reply With Quote
Old 01-15-2017, 01:03 PM   #11
Jeebz
Drives: 2016 Frs
Thanks for all the re-assurance guys. I took it to dealer for free oil change and they did not say anything. Everything seems fine.
Old 01-16-2017, 03:12 AM   #12
humfrz
That's good.
So, lesson learned, back in the day, when a car hit the parking stop, the tires hit first ...... with these cars, by the time the tires hit the stop, the front end has been destroyed .....
humfrz
Old 01-16-2017, 04:28 AM   #13
finch1750
finch1750's Avatar
That's good.
humfrz
Yeah, but the secondary cat is a bit far back lol.
We have all done dumb stuff OP. Next time, pull away slowly and just back up after you hear/feel the initial impact.
Old 01-16-2017, 05:34 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
humfrz: Funny that it's not just these sporty-coupe-ish twins that are low. I noticed that many latest/modern "common/average/family" cars don't have much ground clearance either. +2-3 extra cm to that of ours and that's it. And on contrary almost all cars (including sport-ish) some 30 years ago had high ground clearance. Like only SUVs or more off-road prepped cars (eg. crosscountry/allroad/outback/XV) have these days but back then - all of them were high, including compacts (eg. golf MK1-2)/sedans/saloons/coupes (orig. hachiroku, datsun Z, mustang of first few generations), with body often starting from wheel center line.
And what's weird .. i don't see roads getting better vs that era, to warrant such generic ground clearance reducing trend. On average at least here roads only had became worse.
The Following User Says Thank You to churchx For This Useful Post:
humfrz (01-16-2017)
Parking at LGA - Parking Spot or Park Plus Marriott WRXcellent NY / NJ / CT / PA 5 01-21-2016 04:43 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
Need a reality check - scraped underside of bumper on parking block 1Cor10:23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-24-2014 12:01 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
