#15 |
Drives: 2013 FR-S 10 series [755]
#16 |
They are when the goals are 'low and no rubbing'
Performance really doesn't seem to be in the equation. |
#17 | |
Drives: 2017 BRZ
Tracking is in the equation I think, unless I misunderstood. |
#18 | ||||
Look > no rubbing >>> comfort >>> performance Edit: To the OP, I say just try it, it's not rocket science to go back. The alternative is to find someone who already has what you want and copy them, or spend enough time researching to have actually earned a degree in rocket science. |
#19 |
Off Topic
Op, question. If you want it to look great while sitting and not rub while driving, what about air or air cup suspension? Also, have you talked with @86SPEED? They're a vendor that is here in Las Vegas.
#20 | |||
Not Bаnned Anymore
Drives: Heavily Modified FRS
Haha 18/24 so nearly full stiff Quote:
Edit: just saw your post about you adjusting compression. setting that too high prevents the shock from moving up quickly and limits what the spring can do. If rebound is set lower and compression high you will basicly have pogo sticks on all 4 corners. |
#21 | ||
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | cjd (11-22-2016), Shark_Bait88 (11-22-2016) |
#22 | ||
Drives: 2015 Halo GT86
I'm not getting a low end under 1k coil. I'm just saying that's what most people run here, nothing wrong with it, but I wouldn't be that person. Anyways, thanks for the input everyone, I'm in contact with 86speed as of now. |
| The Following User Says Thank You to Hentai For This Useful Post: | go_a_way1 (11-22-2016) |
| WTB: Toe arms & Coilover (ATLEAST 10k spring rates ) | DavidBob | Want-To-Buy Requests | 0 | 10-31-2016 12:40 PM |
| KW Variant Spring Rates? | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 04-02-2015 10:28 PM |
| Spring and damper rates: front vs rear, explanation needed | Ashikabi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-14-2015 05:21 PM |
| KW V3 and RCE Tarmac II Spring Rates | Plastic Robot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-10-2015 11:54 AM |
| Coilover spring rates for comfort | Barbecue | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-13-2013 12:09 AM |
