Old 11-21-2016, 04:28 PM   #1
Hentai
Hentai's Avatar
Drives: 2015 Halo GT86
Exclamation Coilover Spring Rates - Help Needed!
So I just got some new coilovers.
Mostly will be using these for DD.
I'm wondering if the spring rates of 8kg front and 10kg rear will cause any problems?
I'm not worried about it being harsh for DD or whatever, I'm just concern if the spring rates are too high? Will that cause any problems to the car for mostly DD?
I'm new to the coilovers, mostly just been using springs for my past vehicles, these are my first set and I'm just curious if I have anything to worry about suspension wise.
Thank you!
Hentai is offline   Reply With Quote
Old 11-21-2016, 04:44 PM   #2
wparsons
wparsons's Avatar
Why did you choose those rates? What's your goal with the coilovers?
flickr
Old 11-21-2016, 04:53 PM   #3
Hentai
Hentai's Avatar
Forgot to mention, I'm widebodied, my rsr springs were not stiff enough ,i kept rubbing the inside of the rears, a buddy of mines were running these specs and they hold up fine, test drove his car and went over some small dips and no rubbing issues at all. So thats the main reason why I chose these specs.
Old 11-21-2016, 04:56 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thank you!
Like said above what are your goals?? I run 8k front 9k rear on mine as a DD but my rates are set up for driving on R compounds and pushing the car to the limit on the track. I feel its a good balance
FR-Sky (11-21-2016)
Old 11-21-2016, 05:04 PM   #5
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
How many clicks for damper for spirit DD?
FR-Sky is offline   Reply With Quote
Old 11-21-2016, 05:10 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Depends on how hard I plan on driving and where. Every coilover will be different too depending on quality on valving.
Old 11-21-2016, 05:18 PM   #7
Hentai
Hentai's Avatar
I track atleast once a month with a friend but im not a hardcore track enthusiast. I live in vegas, roads arent that bad, here. My goal is just to have a car that's stiff enough to not rub my fenders, but also not so stiff for DD
just wondering if my rates are in the "A-Okay" zone? But I am more concern about the rubbing issue on the fenders, and not so much for comfort.
So basically my goals: 80% on rubbing issue 20% on comfort driving.
Old 11-21-2016, 05:19 PM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm not sure high spring rates are the right answer...
Spring rates and dampers aren't totally separate... There simply isn't a way to say if that will work for you, be comfortable, etc. or not based on the information given.
I've been running 10/12 on Tein SRC. I've done road trips comfortably. I'll be making changes based on analysis... But not to avoid rubbing... I've been on the stops.
The Following 2 Users Say Thank You to cjd For This Useful Post:
strat61caster (11-21-2016), wparsons (11-22-2016)
Old 11-21-2016, 05:26 PM   #9
FR-Sky
FR-Sky's Avatar
hmm, let say normal mountain spirit drive?
Old 11-21-2016, 05:32 PM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Oh I see, if that's what your trying to solve proper fitting wheels is where you should be looking.
Depending on temps roughly 18 clicks
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
FR-Sky (11-21-2016), wparsons (11-22-2016)
Old 11-21-2016, 05:41 PM   #11
Hentai
Hentai's Avatar
Yea, you are right, wheel fitment + tire size is the optimal way to fix it, but costs way too much for me to atm to change my whole set-up, especially for widebody.
Either way I was going to get coils regardless so I thought it would help a little. Just wanted a good opinion on how these spring rates would help up. Thanks for your input though, now I know people do go above 8k lmao. Almost everyone here in vegas are running BC'S And Megans.
Old 11-21-2016, 05:46 PM   #12
cjd
cjd's Avatar
Drives: 2017 BRZ
BC and Megan... Don't waste your money. Especially because it won't help if you're actually pushing the car. You need to fix the fit.
I don't have 18 clicks...
go_a_way1 (11-22-2016), Shark_Bait88 (11-22-2016)
Old 11-21-2016, 05:49 PM   #13
FR-Sky
FR-Sky's Avatar
My car start bounce up and down in a small motion when damper are mid like 13 clicks,(max 24) Does that means too stiff for normal mountain spirit drive? I have 8k spring rate front/rear
Old 11-21-2016, 05:53 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
What kind of bounce? It could be too much compression or too little rebound... Or something else.
WTB: Toe arms & Coilover (ATLEAST 10k spring rates ) DavidBob Want-To-Buy Requests 0 10-31-2016 11:40 AM
KW Variant Spring Rates? smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 04-02-2015 09:28 PM
Spring and damper rates: front vs rear, explanation needed Ashikabi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-14-2015 04:21 PM
KW V3 and RCE Tarmac II Spring Rates Plastic Robot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-10-2015 10:54 AM
Coilover spring rates for comfort Barbecue Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-12-2013 11:09 PM
