Old 08-04-2012, 09:59 PM   #15
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
how often u all need to check that can?
kendalldwhite is offline   Reply With Quote
Old 08-05-2012, 12:39 AM   #16
dompower
dompower's Avatar
Drives: BRZ sportech
ive done almost 5000km installed like in the picture and there is no oil accumulation.
dompower is offline   Reply With Quote
Old 10-04-2012, 05:49 PM   #17
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I pm'd a Subaru tech in another forum regarding installation as shown above and this is what he had to say...
Actually, this setup with a catch can is not functional, because the left hose is routed back to the intake, therefore some vacuum is always present in the can. The crankcase vapors would not have anytime to settle in the can before they are sucked back into the engine. This setup would be similar to air/oil seperator configuration. On mine the left hose is exposed to atmospheric pressure and since the fitting is on the top side of the can, it allows the vapors to be isolated to the catch can and settle.
This is how he installed the catch can...
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-04-2012, 06:00 PM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by d1ck View Post
also helps preserve your piston rings by creating a vacuum in the crankcase under normal driving.
Could someone please elaborate on that?
Old 10-31-2012, 02:04 AM   #19
Burn
Slack Bum
Burn's Avatar
Hi JPxM0Dz,
This is the exact setup as depicted in the setup instructions in the cusco catch tank
Burn is offline   Reply With Quote
The Following User Says Thank You to Burn For This Useful Post:
JPxM0Dz (10-31-2012)
Old 10-31-2012, 10:45 AM   #20
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
So that catch can only has two lines? If that's the case and both are running to the PVC I foresee some major issues coming. The catch can has to vent, either to the intake or atmosphere. I would steer clear of the Cusco can.
ANTI_LAG is offline   Reply With Quote
Old 10-31-2012, 10:47 AM   #21
ANTI_LAG
ANTI_LAG's Avatar
Also wanted to add that cusco can is meant to go on a one hose PVC system, it goes in between the intake and the Pcv valve.
The Following User Says Thank You to ANTI_LAG For This Useful Post:
Old 10-31-2012, 11:55 AM   #22
Dezoris
Dezoris's Avatar
The install is wrong. If you want to catch PCV blow by you need to connect it to the PCV valve and the intake manifold. Not the breather tube to the intake.
http://www.ft86club.com/forums/showthread.php?t=21079
You can see the PCV valve hose here and the intake manifold hose in this picture running to the radium can.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 10-31-2012, 12:12 PM   #23
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Thanks for the confirmation. I have a feelin that are more than few people running with the wrong configuration
2URGSE
Old 10-31-2012, 12:13 PM   #24
ANTI_LAG
ANTI_LAG's Avatar
So what about catching the oil coming out of the front Pcv hose? Is everyone forgetting it? That is a closed catch can, meaning it must attached to the intake side via either the intake manifold port where the Pcv hose used to go or the front intake port to relieve the internal engine pressure that builds up. With that being said, the cusco can cannot do this, it's a either or situation. You will only be able to catch oil from one line, but oil will travel from both! At this point all that can can do is shine in the engine bay. Your going to et what you pay for with that one.
Old 10-31-2012, 12:15 PM   #25
ANTI_LAG
ANTI_LAG's Avatar
And I hope no one gets the idea to tag both lines in one port in order to achieve this as you would drop each Pcv port on the engine to under .250" of breathing ability.
Old 11-14-2012, 11:40 AM   #26
empower-auto
Kouki-Monster
empower-auto's Avatar
Can someone post an actual correct installation for this Cusco unit?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-14-2012, 11:50 AM   #27
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Hey, post #17 shows a pic of how I believe the unit should be installed to be somewhat functional. Others have installed it differently to pass track regulations.
Some will argue that the Cusco catch can is useless period and non-functional at all by design
But that wasn't your question, so hopefully we won't get a bunch of haters posting useless comments
2URGSE
Old 11-14-2012, 11:57 AM   #28
empower-auto
Kouki-Monster
On a note of functionality .. it would seem that pending you're running the 2nd hose atmospheric .. it does its job just fine.
Rich Anderson
EMPOWER AUTO
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 03:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
Cusco Street Oil Catch Tank 0.6L in stock!!! IslandImportPerformance Engine, Exhaust, Bolt-Ons 0 06-05-2012 12:56 AM
