Old 10-06-2016, 07:23 PM   #15
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Fenix View Post
Here is a past e-mail from Matt at Fortune Auto:
Hmm he might be right but I am on FA500's with swifts as well and even on my race slicks the car is perfectly balanced IMO
edit: isn't their stock recommended ratios 6k front and 7k rear?
Old 10-06-2016, 07:33 PM   #16
Cole
Not a troll
Cole's Avatar
Dude mentioned using a larger front sway, probably to compensate for the rates.
Old 10-06-2016, 07:42 PM   #17
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I doubt I would like softer springs. I might be bumping them up to stiffer spring rates soon. :/
Fenix is offline   Reply With Quote
Old 10-06-2016, 07:57 PM   #18
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Stop worrying about fine tuning the setup and making changes. Get an alignment and sort out the noises because your setup isn't anything aggressive and shouldn't cause any issues if everything was installed properly.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 10-06-2016, 08:12 PM   #19
strat61caster
strat61caster's Avatar
+1 get it aligned, have every nut and bolt tightened, solve problems one by one before 'refining'.
Wheel rub is caused by offset, ride height, or wrong size wheel/tire, the ride height you posted seems reasonable, your spring rates should be stiff enough and the wheel/tire specs are in the ballpark of what's known to fit. You should be able to bolt up any wheel that fits and not have any noticeable change in the rest of your suspension setup, no new clunks or behaviors not associated directly with the change in tire (steering feel, grip, response, etc.)
The only thing that could be going on is if the wheels weren't balanced right? Might be worth having the shop check.
ineedyourdiddly
FS: Custom Bilstein suspension/coilovers Kostamojen Brakes, Suspension, Chassis 11 11-21-2016 03:21 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
