Old 09-19-2016, 11:07 AM   #15
Originally Posted by Norville Rogers View Post
Whatever happened to the oily rag wipe down? That would have stopped it starting..
Cars became way more resistant to rust and people no longer know of the things we had to do to keep them from crumbling away in 3 years. Now even the slightest surface rust seems to be a cause for panic since it is so rare.
Old 09-19-2016, 11:20 AM   #16
JD001
JD001's Avatar
Drives: Subaru BRZ
It would be okay if rust behaved itself stayed as small pimple but it doesn't! It fucking spreads!! Hence panic! It's like an iceberg, 2/3rd hidden! I say panic if see any rust...
Old 09-19-2016, 11:27 AM   #17
Body rust yes. Bolts/nuts, non structural sections, exhaust, suspensions, etc. do not require panic. Touch up if it bothers you but the damned car is not going to fall apart. I have lived my whole life in the rust belt of Canada and have watched the cars get better and better at dealing with rust over 40 years. The days of rotted out, 3 year old cars, ended about 25 years ago (other than Mazda that is. they continue the legacy).
JD001 (09-19-2016)
Old 09-19-2016, 12:14 PM   #18
sirsol66
Drives: 2013 FRS- Hot Lava
Just so its clear, do not sand or bead blast or anything on coil springs. Most modern coil springs have 2-3 different shot peening processes done, with some of the residual hardness layers less than 0.5mm. You don't want to disturb that.
I would spray the coils down with AMSOIL HDMP Or similar wax like coating to seal the surface and keep it from getting worse. Or replace them. Honestly that looks pretty bad for a 2 year old spring; I assume they're using e-coat or just paint as those are the cheapest coatings commercially available for coil springs. Try to get coils with at least dual epoxy powder coating.
sirsol66 is offline   Reply With Quote
The Following 2 Users Say Thank You to sirsol66 For This Useful Post:
makinen (09-19-2016), wparsons (09-19-2016)
Old 09-19-2016, 12:37 PM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have red STI springs in my other car for more than 4 years and I haven't seen rust yet. I agree that the coating was cheap.
How do you get rusted hubs/bearings off? ZionsWrath Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 07-01-2016 09:51 AM
Rusted chipped paint ARTBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 01-31-2016 10:08 PM
Rusted shipped paint ARTBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 01-30-2016 03:46 PM
Rusted exhaust pipe '13 FR-S cheesesteak Issues | Warranty | Recalls / TSB 14 04-15-2014 02:51 PM
Does exhaust will be rusted at some point? Lverasky Engine, Exhaust, Transmission 10 04-12-2013 02:53 PM
