| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: Subaru BRZ
#16 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
OK, got the car leveled (yes leveled!) up on jack stands and checked a few other places for reference, for all the paranoid, detail oriented, even anal people out there that like to do things right, everyone else can just suck it.
![]() Pinch weld, Rocker panel and Threshold are all pretty much on the same plane, so checking any of those spots will work, it's just the threshold is more convenient. Transmission case is definitely not level, it's exactly like the cutaway view of the drive line shows, about a 5 degree decline. Bottom side of the pan is much closer to level but it still angles about 1.5 degrees toward the rear, which make sense since the main drain plug is at the rear of the pan. |
#17 |
Simply Forgotus
Yes, but tip too much and you'll drip too much. Unlike the manual transmission, the Auto is much more sensitive to fluid level. If I'm going to put it up on stands anyway, why not throw a level on it and make sure it's right? Just sayin'. |
#18 | |
Here's a picture:
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Norville Rogers (09-18-2016) |
#19 | |
not playing cards
Ok, OP, I just reviewed the maintenance manual.
The incline of the base of the oil pan matches the incline of the transmission in your transparent view. It is parallel to the bottom of the car. This is the best orientation to extract the most possible fluid out of the pan when changing it. The first steps of the process are: I retract my earlier suggestion. The car must be level.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | BirdTRD (09-17-2016) |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| FRS/BRZ Volume level | Scionguy28 | Electronics | Audio | NAV | Infotainment | 7 | 12-03-2014 07:31 AM |
| Fuel level | GeeTee86 | Issues | Warranty | Recalls / TSB | 6 | 05-21-2013 05:57 AM |
| My oil level was low! | FRSjeff | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 12-15-2012 11:22 PM |
| Another Level 86's | SportInjected | Great Lakes | 4 | 07-30-2012 10:13 PM |
