Old 09-14-2016, 03:20 PM   #15
j0307
j0307's Avatar
Drives: 2015 Subaru BRZ Series.Blue
Originally Posted by MarkR171 View Post
Anything more than a 3mm spacer is unsafe on the stock studs because you won't have enough stud thread on the outside of the wheel for the lugnuts to sit on.
The "two types of spacers" I think you're referring to are hub-centric and non hub-centric which has to do with proper centering rather than whether or not you need extended studs or not.
I think by two types of spacers he means adapters and spacers.
j0307 is offline   Reply With Quote
Old 09-14-2016, 03:25 PM   #16
gramicci101
Off Topic
The two types of spacers he's referring to are slip-on and bolt-on. You're right that you can't use more than a 3mm spacer on the stock studs, but you also can't use any less than a 12mm bolt-on spacer. That's because there isn't enough material under the new lugnuts to guarantee that they won't rip out. So anything between 3-12mm will be a slip-on spacer that requires longer studs. Above 12mm can be either slip-on or bolt-on. I have 20mm and 25mm bolt-on spacers on my car.
Given how much tire is being tucked, I don't think this car has any spacers at all.
Old 09-14-2016, 03:25 PM   #17
MarkR171
MarkR171's Avatar
Drives: '05 Elise
You caught me before I added the edit
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 09-14-2016, 03:26 PM   #18
FX86
Originally Posted by jasonojordan View Post
I like low but that is beyond daily functionality low.
at least his wheel aren't bent inwards looking like the suspension imploded
Old 09-14-2016, 03:44 PM   #19
Icecreamtruk
Drives: Track preped NA FRS
Edit: Actually, you may also be talking about the spacers with stud extensions already on them.
Bingo. I have a couple of those, I use them to adjust handling since I cant swap out my suspension in current time attack class and they can be as slim as 15mm. Whether that car has or not is another story tho.
The Following User Says Thank You to Icecreamtruk For This Useful Post:
MarkR171 (09-14-2016)
Old 09-14-2016, 04:07 PM   #20
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
I have an incredibly revolutionary idea to find out how that car is set up. You see how in the instagram post the owner's page is tagged? Why don't you send the owner a message asking this question.
Yanbags is offline   Reply With Quote
Old 09-14-2016, 04:07 PM   #21
j0307
j0307's Avatar
It says account doesn't exist. I tried.
Old 09-14-2016, 04:17 PM   #22
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Bagged. /thread
Toyarzee is offline   Reply With Quote
Old 09-14-2016, 06:44 PM   #23
vincelive123
Drives: Scion FR-S
Sti alloy wheels with air ride probably.
vincelive123 is offline   Reply With Quote
Old 09-14-2016, 07:06 PM   #24
Yanbags
Yanbags's Avatar
That's unfortunate. :/
Old 09-14-2016, 11:00 PM   #25
df.dima
Drives: FR-S and Mazda 3 Sky
Evidence destroyed, returned to stock, sold as "never modified, stock, babied"
I remember there were a few guys running extremely low and static, maybe go through the aggressive wheels thread in fr-s section, if you really wanna go that way.
df.dima is offline   Reply With Quote
Old 09-15-2016, 02:10 AM   #26
vincelive123
Drives: Scion FR-S
You can run a 5mm spacer. I had it on mine in the front and travelled for 3000+ miles around the west coast. No issue. 5mm is the max load.
Old 09-15-2016, 11:22 AM   #27
c4lvinnn
Drives: Toyobaruion
It's funny how people think driving low is hard.
c4lvinnn is offline   Reply With Quote
Old 09-15-2016, 11:50 AM   #28
ModBargains.com
ModBargains.com's Avatar
Unfortunate they didn't actually tag the account in the photo because that will at least update as/if the person changes their IG handle. Looks like it could be static or on air, height could be realistic for both unless someone knows for certain
ModBargains.com is offline   Reply With Quote
Running E-85 Tenshi_FRS Southern California 3 06-05-2015 07:01 PM
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 07:18 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Running e85? HSayaovong Engine, Exhaust, Transmission 16 04-24-2014 11:05 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
