#15 | |
The only thing that would be an issue is if you had e85 and tune in car and dealer flashed back to stock petrol tune. |
#16 |
oh, if you want to get your iam back to 1 quickly, do a few light steady throttle runs from 2000 to 5000 or so in second gear , just light steady throttle and let rpm build fairly slowly and smoothly
#17 | |
Drives: Ultramarine toyobaru
According to my OFT this morning it was still running OFH2 ots tune... I reflashed it anyway with an updated version and somehow that still solved the problem. Seems to be starting at IAM 1 and staying there for now. |
#18 |
Drives: Toyota 86 GTS
OFT doesn't show you what rom is on the ECU, it only shows the previously flashed slot.
| The Following 2 Users Say Thank You to Wayno For This Useful Post: | headlikeahole (09-09-2016), wparsons (09-09-2016) |
#19 |
I'm glad we figured out the issue. However, I'm pretty pissed they went ahead and flashed my ECU after leaving specific instructions not to.
I even witnessed the service desk write "DO NOT touch OBDII port, car is tuned" on the service slip. |
#20 | |
If you knew the checksum value CVN of the stock rom and the CVN of the tuned rom you could check that, i carnt remember if oft will read CVN in info or ecu screens. |
#21 | |
Drives: Full race 4cyl boxer
Did your IAM "vary" - yes Was it "irregular" - Yes by your own admission. Therefore your IAM "fluctuated". I would be asking: "Did they clean your MAF sensor?" If - YES, "did they use the approved cleaner or just something from the local auto parts store?" I see now that you solved the problem. Sorry I don't always read the entire thread before commenting, I'm just a troll that way... So you essentially TOLD the dealer that you do not want your warranty any more?
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
#22 | |
IAM started at .70 (and always .70) the minute the key was turned. OFT showed IAM 1 with key on but only as default. I wouldn't call that fluctuating, but I see your point. My car is no longer under warranty and also this was at a Subaru dealership (its a scion). If I did need warranty work it wouldn't be with them. |
#23 | |
Ah, I guess I am spoiled with the 100,000 mi, 7 year warranty. And as others have pointed out, the startup behavior is different with a tune vs. stock. I would be pissed if they flashed the ECU when explicitly told not to. If you had FI and they did that, they could be held liable for a new engine when it detonates.
