#15 |
I have a jug of distilled water sitting in my garage to top off with. I have gone through about 2/3 of that jug (bought it roughly a year ago lol). I usually notice the coolant evaporating on hot days/track days. I usually just fill it in the middle of the high and low lines.
#16 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
#17 | |
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
Ok, interesting. Done a couple of track days and skidpan events in 110degree weather, no usage over 15k miles. Sent from my iPhone using Tapatalk
-JvV-
#18 |
100K miles and I had to add my first cup of distilled water last week.
#19 | |
Interestingly, my service schedule shows coolant replacement at 195 k km. ![]() Sent from my iPhone using Tapatalk
-JvV-
#20 |
Yep. I am getting to the big service. Also still have the original tranny and diff oil in it. No issues with anything though.
#21 | |
Over here we do the diff oil every 30k km according to the schedule. Sent from my iPhone using Tapatalk
-JvV-
#22 | |
Every 30K seems way excessive.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (09-08-2016) |
#23 | |
-JvV-
| The Following User Says Thank You to jarnojvv For This Useful Post: | Tcoat (09-08-2016) |
#24 |
...Just add nauseum
Drives: 2003 (AP1) S2000
So, I don't know if this is definitive but here goes.
I lived in NY and AK, never used a drop. Moved to Miami, leave town for several weeks for work, car parked outside in the sun. Return to find the coolant bottle a little lower every time... And it's not like I'm driving it when I'm gone. The water is evaporating, because the bottle isn't sealed. I take the thing apart on a regular basis. Never found any coolant residue anywhere it doesn't belong. I've used a few cups of distilled water in a year, both turbo and not.
There are many ways to displace.
-Spartarus |
#25 |
Drives: 2015 Ultramarine FR-S
#26 | |
Maybe your eyeballs are playing tricks on you .. ?? Maybe the crickets pissed in the overflow tank .. ?? Maybe the cooling system burped ... ?? ![]() humfrz |
| The Following 4 Users Say Thank You to humfrz For This Useful Post: |
#27 | |
My usual spiel on this: The coolant reservoir is an expansion tank not a storage container. When hot the coolent expands and gets held in the tank. When the engine cools it get's sucked back into the system. A low expansion tank is NOT an indication of a low cooling system but still should be between the lines when hot. Don't fill it to the top when cool or it will spill. The tank just makes it easier to add water/coolant and being filled is not a critical aspect of the system. Back in the day car's just dealt with the expanding coolant by pissing it out on the ground until the level was equalized between hot and cold but for some reason they frown on that now.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | G-awesome (09-08-2016), humfrz (09-08-2016), SlammedSilly (09-08-2016), tCsonfrs (03-01-2017), zc06_kisstherain (09-08-2016) |
#28 |
Question about co
So I know that you are supposed to fill your coolant by starting the engine and letting the air work itself out of the system. My question is that with the engine running should there be coolant flowing into the overlow tank? If so is it all the time or only when the thermostat is open?
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
| Coolant Question | fantah | Hawaii | 0 | 08-01-2014 05:06 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
| Simple frs coolant question | Young_makaveli | Engine, Exhaust, Transmission | 24 | 12-25-2013 04:42 PM |
| Coolant Question | boredom.is.me | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-15-2013 07:50 PM |
