Old 08-16-2016, 05:34 PM   #15
humfrz
Originally Posted by bshep View Post
They said the entire rear end is gone, but they are going to fix it and cover everything besides a rental.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Well, that's good.
You might consider asking them what they mean by "the entire rear end is gone".
I (we) would like to know.
humfrz
Old 08-16-2016, 06:05 PM   #16
bshep
Drives: 2013 scion frs hot LAVA
The guy had no idea. He said with some interesting hand movements that a piece inside the rear end that makes it move went out so they have to replace everything. It had the normal metal shavings on the drain plug
bshep is offline   Reply With Quote
Old 08-16-2016, 06:11 PM   #17
gramicci101
Off Topic
That sounds like the ring or pinion gear shit itself. But that wouldn't have a normal amount of metal shavings, it would have chunks of gear teeth.
Old 08-16-2016, 06:19 PM   #18
PMPB
Drives: BRZ Sport-tech
The symptoms don't match what the dealer is saying?! If the "the entire rear end is gone", this would most likely make a horrible noise while accelerating (amazing that it's still driveable), and then be relatively more quiet while the clutch pedal is depressed.
Also, if any rear end components lunched themselves, their respective oil baths would look like oily mercury, and the magnetic drain plugs like metal cacti.
PMPB is offline   Reply With Quote
Old 08-16-2016, 06:34 PM   #19
bshep
Well they said it wouldn't be making the noise when I picked it up.... soooooooooo if it is I guess they can go from there and fix whatever else it may be. They are on their own dime now. But for now I'm stuck driving a Ford focus.... whoohoo rental cars I'll update as I find out more. They also were going to put in the oem gear oil I told them no thank you that I would bring my own, but I can not find a place in town that sells motul 300 which is what I've seen to be everyone's favorite. Any other suggestions?
Old 08-16-2016, 06:43 PM   #20
gramicci101
Off Topic
Check the Subaru dealership. I know mine sells Motul products. You'll need two quarts.
Old 08-16-2016, 06:44 PM   #21
bshep
Ok thank you
Old 08-16-2016, 06:47 PM   #22
PMPB
I assume you're in Florida. Most people who switched transmission oil did it for Racing reasons, or because the transmissions shifts like shit when the tranny is cold. Florida doesn't really get "cold" does it (like into the 30's).
I think the OEM fluid should be just fine for you? If you do a lot of low speed tight tight turning (parking lots), you could always switch out the differential fluid to Gear300 later. It's a bit more slippery than the OEM stuff and tends to reduce the juddering from the rear end when making tight turns, IIRC.
Old 08-17-2016, 03:24 AM   #23
pantdino
Drives: Firestorm 2013 FR-S
I'd let them put Oem fluid in and change it later after everything seems good.. You don't need them messing something up in the job then when you bring it back in 2 weeks saying it's not covered bec u put in non-Oem fluid.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 08-18-2016, 09:12 PM   #24
bshep
They ended up replacing the entire rear differential and she is running like a dream. No crazy noises and it's actually taking off better!!! Whoohoo!!! Went back with oem fluids.
The Following 3 Users Say Thank You to bshep For This Useful Post:
Drakiv (08-19-2016), gramicci101 (08-18-2016), humfrz (08-18-2016)
Old 08-19-2016, 01:55 PM   #25
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
post deleted
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 08-19-2016, 05:11 PM   #26
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Originally Posted by number_Un0 View Post
my car is making the same noise, it started happening after my transmission was replaced under warranty for the 5th gear grind, I've been driving it like this for 8k miles now. (im at 32k). I've just been to lazy and didnt feel like putting my stock exhaust back on and take it to the dealer.
You shouldn't have to do that. There's no way they can peg a bad TOB on an exhaust system, but I'd love to see them try.
Silver Cervy is offline   Reply With Quote
Old 08-19-2016, 07:13 PM   #27
number_Un0
Drives: 2013 FRS 10 series #0001
Rather play it safe. I've heard too many stories of dealerships refusing to do warranty work because of a mod not related to the problem.
number_Un0 is offline   Reply With Quote
Old 08-20-2016, 03:50 PM   #28
exE36M3
FWIW - a throwout bearing isn't going to make any noise when you are driving. It just floats there until you push the clutch in and engages the pressure plate. When it starts to go, it'll make a metallic whirring noise or chirping when you push the clutch in. When it TOTALLY goes you may hear horrible scraping noise and/or not get any clutch engagement at all - when you push the clutch in.
The TB on my 1990 Miata lasted over 120k miles and my BMW M3 120k miles as a reference.
If your car makes ANY kind of noises at speed, and it's NOT related to the engine revs and it's NOT an automatic, then it will most likely be driveline or wheel.
Sorry, I didn't see your post sooner but glad the dealer got it right for you!
exE36M3 is offline   Reply With Quote
differential, loose bolt, transmission
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 09:10 PM
Runduce 6-Speed Transmission Gear - 500hp botbs Engine, Exhaust, Transmission 10 11-22-2015 03:59 PM
is it ok to slip my clutch often in 2nd gear when my rpm is below 2k? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 88 06-17-2015 07:12 PM
What's this clunk sound coming from 2nd gear after letting go of the clutch ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 17 04-30-2015 03:14 AM
Cold morning and horrible grinding/screeching sound Books Issues | Warranty | Recalls / TSB 1 11-14-2012 03:18 PM
