#15 |
| The Following User Says Thank You to FX86 For This Useful Post: | humfrz (08-16-2016) |
#16 |
not playing cards
Please do follow up if you learn anything. Good luck.
#17 |
Keep ICE alive+manuals
Drives: 2015 Hot Lava 6 spd
AC idle problem
Yea like some have said here, its a smaller engine problem, the AC kicking on and off bogs a small motor, mine used to do it all the time sometimes dropping As low as 300 rpm until i bought the Vishnu OFT, now that it has the new software and a higher idle it doesn't do it anymore. The Vishnu tablet was a great upgrade and puts the idle where it should be, around 800, these motors idle too low from the factory.
#18 | ||
not playing cards
Welcome to the forum.
#19 |
Yea mine wasn't every 3 seconds but each vehicle no matter if the same model and make varies in operation. And yes an average of 650 rpm has been a staple for an idle for a few decades, but it doesn't mean that its a great idle for these engines. Mine before my Vishnu tablet install would idle as low as 500 occaisionally and would feel like it wanted to stall, especially when i would put the AC on.
#20 |
Drives: 2014 BRZ Limited 6MT
If u turn on the AC but turn the fan speed down low it can happen that often. The compressor will kick on and off at low fan speed. If the fan is turned high the comp will stay on and it'll only have a one time bog when it kicks on the first time. If it's bogging and u see the compressor staying on then it's not the AC doing it
| Car running poorly after check engine light cleared | AlexK | Engine, Exhaust, Transmission | 4 | 07-07-2015 04:16 AM |
| Slight buzz at 1,500 RPM | ericmpena | Engine, Exhaust, Transmission | 5 | 05-02-2014 09:35 AM |
| Why does it stutter when I accelerate? | dro | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 10-14-2013 02:29 PM |
| Owner's manual slight confusion about engine break in period... | davey90 | AUSTRALIA | 48 | 09-05-2012 10:51 PM |
| Toyota FTS report engine issues with FR-S running 91 octane | DYOLF26 | Issues | Warranty | Recalls / TSB | 24 | 08-06-2012 02:22 PM |
