Old 08-16-2016, 01:36 PM   #15
FX86
Dang hot rod ........
it always happens in 1st and 2nd gear...sometimes 3rd..4th gear only in mexico
The Following User Says Thank You to FX86 For This Useful Post:
humfrz (08-16-2016)
Old 08-16-2016, 02:31 PM   #16
Originally Posted by select20 View Post
Thanks for all the replies everyone. Much appreciated. Will take it to shop and get it checked just for peace of mind.
Please do follow up if you learn anything. Good luck.
Old 08-16-2016, 11:10 PM   #17
HotlavaFRSGT86
Keep ICE alive+manuals
HotlavaFRSGT86's Avatar
Drives: 2015 Hot Lava 6 spd
AC idle problem
This only happens when it's like 90+ outside and it's very noticeable. If I'm running the AC at night or when it's not as hot, it never stutters. Also, it's a consistent stutter, like every 3 seconds.
Really curious if anyone else has had this.
Yea like some have said here, its a smaller engine problem, the AC kicking on and off bogs a small motor, mine used to do it all the time sometimes dropping As low as 300 rpm until i bought the Vishnu OFT, now that it has the new software and a higher idle it doesn't do it anymore. The Vishnu tablet was a great upgrade and puts the idle where it should be, around 800, these motors idle too low from the factory.
HotlavaFRSGT86 is offline   Reply With Quote
Old 08-16-2016, 11:28 PM   #18
Welcome to the forum.
Not every three seconds.
No. 650 RPM has been a standard for many decades.
Old 08-18-2016, 11:47 PM   #19
HotlavaFRSGT86
Yea mine wasn't every 3 seconds but each vehicle no matter if the same model and make varies in operation. And yes an average of 650 rpm has been a staple for an idle for a few decades, but it doesn't mean that its a great idle for these engines. Mine before my Vishnu tablet install would idle as low as 500 occaisionally and would feel like it wanted to stall, especially when i would put the AC on.
Old 08-19-2016, 12:46 AM   #20
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
If u turn on the AC but turn the fan speed down low it can happen that often. The compressor will kick on and off at low fan speed. If the fan is turned high the comp will stay on and it'll only have a one time bog when it kicks on the first time. If it's bogging and u see the compressor staying on then it's not the AC doing it
tofurun is offline   Reply With Quote
Car running poorly after check engine light cleared AlexK Engine, Exhaust, Transmission 4 07-07-2015 04:16 AM
Slight buzz at 1,500 RPM ericmpena Engine, Exhaust, Transmission 5 05-02-2014 09:35 AM
Why does it stutter when I accelerate? dro Scion FR-S / Toyota 86 GT86 General Forum 9 10-14-2013 02:29 PM
Owner's manual slight confusion about engine break in period... davey90 AUSTRALIA 48 09-05-2012 10:51 PM
Toyota FTS report engine issues with FR-S running 91 octane DYOLF26 Issues | Warranty | Recalls / TSB 24 08-06-2012 02:22 PM
