#15 | |
Slow driver, fast biker.
Drives: '16 86, '00 Celica GTS, Sportbikes
Toyota won't sell you the 18" TRD wheel and tire package in the USA in a non-staggered configuration. This configuration certainly does not "mess with the traction control systems" though I can imagine a more extreme setup may be a problem. |
#16 | |
Reworded for your enjoyment. It's a package, of course they won't sell a package broken up, it wouldn't be called a "package". You can still order the wheels individually though.
#17 |
Off Topic
What messes up the traction control systems is not the tire width, it's the overall diameter. If the front tire takes 77 inches to roll out and the rear tire takes 85 inches to roll out, now your tires are rotating at two different speeds and the traction control freaks out. So if you want to run staggered, you try to keep the overall diameters very similar. Usually this means jumping three tread width sizes. 215/40-18 (24.77 OD) on the front, 245/35-18 (24.75 OD) on the rear. That kind of thing. 225f/255r is very common; 235f/265r is somewhat common. Or you keep the sizes square and not worry about it.
#18 | |
Performance Ricer
Drives: 19 WRX, 19 ND2
Im guessing 245s: +rim protection +grip -handling -steering responsiveness -ride quality Is this correct? What about just the 245s in the rear? |
#19 | |
Off Topic
On an 8" wheel, I'd do 225's all around. A 245 would probably fit, but it'd be pinched. If you were doing 8.5" or 9" width, I'd do a 245. There's zero reason to run staggered tires on square wheels. If you want the back to come out a little to be flush with the fender, spacers work just fine. The steering wheel will be a little heavier with 245's because it has more traction. Gas mileage will be a little worse, because you're moving a heavier tire. Ride quality depends on the tire itself, not the size. Going from the OEM Primacies to Pilot Super Sports in OEM size, ride quality suffered a lot because the sidewall is so much stiffer. Why do you want wider tires? If you're putting down a lot of power or you're taking it to the track or you need more traction or if you just want huge fat tires to look cool, great. Just make sure you know what the tradeoffs are before you make your decision. |
#20 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
@gramicci101
Thanks for all the info. It's helped me out enough. I've made my final choice of going 245/35/18 on 18 x 8.5
Instagram: Gabe.it.the.ole.college.try |
#21 | |
Performance Ricer
#22 |
Indulgent Tormenter
TireRack has fewer than 3 and it takes 7-10 business days fr Enkei to send them more. Sad Panda
#23 | ||
Off Topic
http://www.ft86club.com/forums/showthread.php?t=20872 Quote:
http://www.oakos.com/Merchant2/merch...egory_Code=TS9 Also, when you do get them, post a pic thread so it can be added to the wheel database. There are no TS9's listed right now. Edit: Here's an 18x8.5 +42 with a 245 tire. The TS9 is a +40, so they would be pushed 2mm further out than these are. He also went with 245/40 instead of 245/35, so his tire is about an inch taller than OEM. http://www.ft86club.com/forums/showp...5&postcount=67 Last edited by gramicci101; 07-22-2016 at 05:24 PM. |
#24 | |
Indulgent Tormenter
Pictures definitely coming!
| wheel width | SlammedSilly | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-12-2016 05:15 PM |
| Wheel Width | gmanvilla1@gmail.com | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 01-17-2016 01:39 AM |
| Ideal wheel width? | hail2thetheif | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 02-13-2014 10:54 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
