Old 07-21-2016, 04:39 PM   #15
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Originally Posted by swarb View Post
Don't run staggered. It is a low powered car. And staggered will mess with the traction control systems. If you want equal distance to the fender front/rear, get a small 3-5mm spacer to adjust.
Toyota won't sell you the 18" TRD wheel and tire package in the USA in a non-staggered configuration. This configuration certainly does not "mess with the traction control systems" though I can imagine a more extreme setup may be a problem.
Shinigami301 is offline   Reply With Quote
Old 07-21-2016, 05:04 PM   #16
swarb
And staggered can mess with the traction control systems.
Reworded for your enjoyment.
It's a package, of course they won't sell a package broken up, it wouldn't be called a "package". You can still order the wheels individually though.
Old 07-21-2016, 05:48 PM   #17
gramicci101
Off Topic
What messes up the traction control systems is not the tire width, it's the overall diameter. If the front tire takes 77 inches to roll out and the rear tire takes 85 inches to roll out, now your tires are rotating at two different speeds and the traction control freaks out. So if you want to run staggered, you try to keep the overall diameters very similar. Usually this means jumping three tread width sizes. 215/40-18 (24.77 OD) on the front, 245/35-18 (24.75 OD) on the rear. That kind of thing. 225f/255r is very common; 235f/265r is somewhat common. Or you keep the sizes square and not worry about it.
Old 07-22-2016, 03:19 PM   #18
WorldRallyB
Performance Ricer
Drives: 19 WRX, 19 ND2
I have some questions about a similar situation, I'm getting 18x8s. Cant decide if i should go 225/40s or 245/35s tires. Pros/Cons with each?
Im guessing 245s:
+rim protection
+grip
-handling
-steering responsiveness
-ride quality
Is this correct? What about just the 245s in the rear?
WorldRallyB is offline   Reply With Quote
Old 07-22-2016, 04:10 PM   #19
gramicci101
Off Topic
+rim protection
+grip
-handling
-ride quality
What is the offset?
On an 8" wheel, I'd do 225's all around. A 245 would probably fit, but it'd be pinched. If you were doing 8.5" or 9" width, I'd do a 245. There's zero reason to run staggered tires on square wheels. If you want the back to come out a little to be flush with the fender, spacers work just fine.
The steering wheel will be a little heavier with 245's because it has more traction. Gas mileage will be a little worse, because you're moving a heavier tire. Ride quality depends on the tire itself, not the size. Going from the OEM Primacies to Pilot Super Sports in OEM size, ride quality suffered a lot because the sidewall is so much stiffer.
Why do you want wider tires? If you're putting down a lot of power or you're taking it to the track or you need more traction or if you just want huge fat tires to look cool, great. Just make sure you know what the tradeoffs are before you make your decision.
Old 07-22-2016, 04:14 PM   #20
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
@gramicci101
Thanks for all the info. It's helped me out enough.
I've made my final choice of going 245/35/18 on 18 x 8.5
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 07-22-2016, 04:32 PM   #21
WorldRallyB
Performance Ricer
What is the offset?
Going with TSW nurburgrings with 18x8 +35mm for looks, weight, costs mostly.. with the potential chance of a BBK and coilovers down the road.
Old 07-22-2016, 04:36 PM   #22
ShadowReaper
Indulgent Tormenter
TireRack has fewer than 3 and it takes 7-10 business days fr Enkei to send them more. Sad Panda
Old 07-22-2016, 04:47 PM   #23
gramicci101
Off Topic
That will look perfect with 225's and won't have any problem clearing a spring and strut suspension.
http://www.ft86club.com/forums/showthread.php?t=20872
That's disappointing. Have you tried forum sponsors? They might have it in stock or be able to get it faster.
http://www.oakos.com/Merchant2/merch...egory_Code=TS9
Also, when you do get them, post a pic thread so it can be added to the wheel database. There are no TS9's listed right now.
Edit: Here's an 18x8.5 +42 with a 245 tire. The TS9 is a +40, so they would be pushed 2mm further out than these are. He also went with 245/40 instead of 245/35, so his tire is about an inch taller than OEM.
http://www.ft86club.com/forums/showp...5&postcount=67
Old 07-23-2016, 09:07 PM   #24
ShadowReaper
Indulgent Tormenter
No Worries, they just got back in stock. I pulled the trigger. Should be here this week or next.
Pictures definitely coming!
wheel width SlammedSilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-12-2016 05:15 PM
Wheel Width gmanvilla1@gmail.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-17-2016 01:39 AM
Ideal wheel width? hail2thetheif Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-13-2014 10:54 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
