Old 07-06-2012, 09:25 AM   #15
86boyAF1
Drives: 1JZ-GTE Toyota Mark II, Toyota bB
Originally Posted by adprokid View Post
The numbers are good considering the OEM tires
This also a good point because during these clutch dump runs, the driver is forced to wait out the wheel spin. Better tires would equal less wheel spin, but increased stress on the clutch and transmission.
86boyAF1 is offline   Reply With Quote
Old 07-06-2012, 10:18 AM   #16
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
As they mentioned the only real reason the BRZ is so 'slow' from 0-60 is because of the required upshift at 59mph from first to second. If the car could just be left in first than I'm sure it would be quite a bit quicker. That said, who really cares about that stat unless you are racing other slow cars on the street.
SkitterSkotter is offline   Reply With Quote
Old 07-06-2012, 10:36 AM   #17
eifer
Drives: Scion FR-S (Hot Lava)
It's a 2l 4cyl car. I wouldn't really stress about the 0-60, especially when you have to up shift at 59 lol.
eifer is offline   Reply With Quote
Old 07-06-2012, 11:12 AM   #18
Turbowned
Turbowned's Avatar
It does 0-59 in 6.5sec, who gives a $#!t about that last MPH.
Old 07-06-2012, 11:20 AM   #19
Tbxgz
Tbxgz's Avatar
Drives: 2013 BRZ Limited 6MT
I also think this is just a myth. I've seen videos of the car at 60 rolling at 7400 rpms in 2nd. After my break-in, I will test this out. Regardless, this is just chatter at this point. The car feels like a 6 second car. It doesn't feel underpowered. nuff said.
Tbxgz is offline   Reply With Quote
The Following User Says Thank You to Tbxgz For This Useful Post:
tripjammer (07-07-2012)
Old 07-06-2012, 05:41 PM   #20
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
59 MPH is max for 2nd
What are you using for the accurate MPH read-out? The display could easily be adding 1 MPH to the precise reading to make the car seem faster.
The correct rotations per mile of the 215/45R17 Primacy tires is 844 according to Michelin. The differential has a 4.1 ratio and the gear ratios are: 3.626 2.188 1.541 1.213 1.0 and 0.767 so the accurate speeds at the 7450 RPM fuel cut-out are:
60*7450/4.1/844 ./[3.626 2.188 1.541 1.213 1 .767] which equals:
35.6 59.0 83.8 106.5 129.2 168.4
So you would need to shift to 3rd to reach 60 MPH. But, who really cares that the 0-60 time is slow because of the second shift?
DSPographer is offline   Reply With Quote
The Following User Says Thank You to DSPographer For This Useful Post:
Tbxgz (07-06-2012)
Old 07-06-2012, 05:45 PM   #21
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I've seen plenty of videos showing it only takes two shifts to get to 60mph. I don't know what you guys are talking about.
SUB-FT86 is offline   Reply With Quote
The Following User Says Thank You to SUB-FT86 For This Useful Post:
Old 07-06-2012, 06:25 PM   #22
DSPographer
Well after 2 shifts you would be in 3rd gear. You can reach over 83 MPH in 3rd gear.
Old 07-06-2012, 06:36 PM   #23
SUB-FT86
86 Member
[ame="http://www.youtube.com/watch?v=2FnnpDofqUc"]0-200 km/h : Subaru BRZ (Motorsport) - YouTube[/ame]
