Old 06-29-2016, 05:03 PM   #15
FNCrazy
Rambling Man
FNCrazy's Avatar
Drives: 2013 FR-S 6MT - In Heaven Now
I'm in love! What mods do you have? So I'd call him, get the gear, and have someone locally (not me!) install it? Before I bug him, ballpark what might the gear cost?
Oh, and any changes to the speedo? Seems like there would be.
Thanks so much! *Exactly* what I'm looking for!
Sent from my SM-G935V using Tapatalk
FNCrazy is offline   Reply With Quote
Old 06-29-2016, 08:32 PM   #16
Cole
Not a troll
Cole's Avatar
Originally Posted by nikitopo View Post
If you need more acceleration, the best approach is to have more power or less rotating mass.
So something like a light weight crank pulley?
Paging @justatroll
The Following User Says Thank You to Cole For This Useful Post:
FNCrazy (06-29-2016)
Old 06-29-2016, 08:59 PM   #17
FNCrazy
Rambling Man
FNCrazy's Avatar
Paging @justatroll
I've been leery of that, I don't know why exactly. Partially I can't imagine it doing much good. Like I know anything though
Old 06-29-2016, 10:22 PM   #18
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
.... light weight crank pulley?
"Crank Pulley"???!!??
Slooowly I Turned.... STEP BY STEP
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Cole (06-29-2016)
Old 06-30-2016, 12:40 AM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by FRS Justin View Post
I would run a 4.56 ratio then it will still let first gear be usable and have a lot more bottom end. 120mph will be easy to reach in 6th 5th gear will max out around 104mph. The most I would do is a 4.88 but that is a extreme street gear and first is pretty useless.
When your ready to get a set call Mark at spencer fab in N.H. he will hook you up.
Hey Justin, long time to talk
Why 4.56 ratio gives a so small top end in 5th gear? I was thinking 5th gear would give something closer to 120mph @7400 rpm. I am using a gear ratio calculator: http://www.apexgarage.com/tech/gear_ratios.shtml
Is the actual speed much lower than the theoretical? I have a 3.7 FD and in 5th I max out around 145mph. In my car, the actual speed is the same with the theoretical.
Old 06-30-2016, 12:53 AM   #20
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Here is also a picture with the calculations:
Old 06-30-2016, 01:03 AM   #21
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Paging @justatroll
We said less rotating mass in general. If you read the complete thread, you 'll find specific examples. First step is to use a much lighter set of wheels and tires. If you also question this, then you don't know what you are talking about.
Old 06-30-2016, 02:27 AM   #22
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Yes rear diff gears,
I ran a 13.58 1/4 mile with a 4.56gear
what other mods do you have to run that time!?
Dr. BRZ is offline   Reply With Quote
Old 06-30-2016, 03:23 AM   #23
FRS Justin
Drives: 2013 Asphalt FRS
Ya I screwed that one up what I meant was 4th topped out not 5th..
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 06-30-2016, 03:26 AM   #24
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Old 06-30-2016, 03:32 AM   #25
FRS Justin
This is the list I have to run 13.58
1: PPE merge collector header and overpipe
invidia N1 full exhaust
2: Airaid CAI
3: Delicious tuning Flexfuel kit and STG 2 tune....
4: 4:56 gears
5: Hoosier drag radials.... That's it
6: You must have no fear and worries about breaking your car!!!!!
I try to break it every pass.... Launching at 8000 RPMS and dropping the clutch.
good luck
and no I will not tell you how I went 13.47 because I plan to go back to N/A and smash the current record.
NOTE All of these times the car had full interior and A/C
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
chaoskaze (06-30-2016)
Old 06-30-2016, 06:46 AM   #26
Dr. BRZ
Dr. BRZ's Avatar
2: Airaid CAI
4: 4:56 gears
good luck
e85 tune, 91 or 93 tuned?
Old 06-30-2016, 07:36 AM   #27
FRS Justin
E85
710whp
Old 06-30-2016, 07:39 AM   #28
FRS Justin
DR. BRZ My tuner flew in for the weekend to go to the track with us you should come down to San Antonio raceway park and hang Friday and Saturday...
710whp
Where to buy LSD & Final Drive/Gear? GT86_PRAGUE User/Vendor/Sponsor Reviews, Feedback, Comments 4 01-09-2015 07:42 PM
Tuning adjustments for different final drive ratios? PantsDants Software Tuning 9 01-29-2014 03:18 PM
Guesses about Gear Ratios and Wheel Torque Deslock Engine, Exhaust, Transmission 63 08-27-2013 01:42 AM
any way to change the gear ratios in manual? SuperDave Engine, Exhaust, Transmission 17 10-19-2012 10:07 PM
Guesses about Gear Ratios and Wheel Torque Deslock BRZ First-Gen (2012+) — General Topics 4 12-01-2011 06:15 AM
