Old 06-28-2016, 06:38 PM   #15
ChrisSC300
Drives: 2014 SWP BRZ
Thank you @CounterSpace Garage. I forgot @Racecomp Engineering had a street camber plate option. I will shoot them an email to see if they are compatible with my Bilstein B8's.
Been a huge fan of RCE. Quality products that actually produce on the Track. I have the Tarmac Springs and could not be happier.
BTW just ordered my first of many products from CSG, Winmax W3's. Looking forward to doing more business with y'all.
CSG and RCE are a huge asset to this community. We thank you.
ChrisSC300 is offline   Reply With Quote
The Following User Says Thank You to ChrisSC300 For This Useful Post:
Racecomp Engineering (06-29-2016)
Old 06-28-2016, 07:14 PM   #16
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Sounds good. You were in luck. They were the last set of W3s on the shelf for another couple of weeks. We'll be getting another batch in soon. Thank you!
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
ChrisSC300 (06-29-2016)
Old 06-29-2016, 08:00 AM   #17
swift996
swift996's Avatar
Originally Posted by Infinity View Post
Did you mean caster?
No, not at all. It's camber that's the most important for the front struts, big improvements to grip during cornering will be found as you move past 2.5 degrees.
He may have been talking about caster, but I will take the ideal amount of camber over the ideal amount of caster any day of the week.
I'm not debating camber, obviously that's more impactful for corning contact area on a tire, I'm just saying proper caster set-up on this car is pretty key. Camber is certainly more important.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-29-2016, 08:19 AM   #18
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I purchased the Velox ones. They are a great product. No problems running stock dampers or the switch to RCE Tarmac 2 coilovers.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
BRZHarley (06-30-2016)
Old 07-18-2016, 01:01 AM   #19
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Both are great options in my opinion .
VerusEric is offline   Reply With Quote
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
SkAsphalt (07-28-2016), Ultramaroon (07-18-2016)
Old 07-26-2016, 04:12 PM   #20
Cybmx
Drives: 2016 Hyperblue Brz
Forgive me if I sound dumb, but what if I rotate the velox camber plate 120 degree and installed it that way, wouldn't I gain camber and caster at the same time?
Cybmx is offline   Reply With Quote
Old 07-26-2016, 05:47 PM   #21
strat61caster
strat61caster's Avatar
Hypothetically yes, the Velox plates are relatively symmetrical and rotating to achieve additional caster looks possible.
However after looking at the trigonometry you're basically ending up with instead of 100% camber adjustment a ratio of about 1:1.7 camber:caster gain. These aren't real numbers but ballpark you'd go from gaining say 2 degrees of camber to just 1.2 degrees while picking up 1.7 degrees of caster.
Most people feel that this car has adequate caster from the factory, it's not a Miata or S2k (and I presume Honda FWD cars) that comes with low caster (5 degrees or less I believe) and benefits by increasing the caster. OE comes to about 6 degrees and the Raceseng plates allow for an additional degree approximately.
Contrary to the Miata and S2k, with a Macpherson strut front in this car has a stronger need for static negative camber because it doesn't gain camber under compression like the double wishbone suspension cars mentioned above.
For reference, my camber plates give me -2.5 degrees, the last event I ran I had them maxed out at -3.6 degrees of camber per side (I also have camber bolts), and I believe my car would have been better if I had more camber in it. There's no way I'm even going to think about sacrificing camber for caster at this point.
I've read it's a common tradeoff on Miata and S2k's to balance your caster/camber, but they have a completely different suspension design that has different strengths and weaknesses from the FR-S/BRZ.
tl;dr The 86 with an additional -2 degrees of camber over stock will be significantly better (more grip) than the 86 with an additional 2 degrees of caster. By rotating the plates you are sacrificing camber for caster, likely to the point where you are negatively affecting your performance by not having enough camber for your front tires to operate properly during cornering.
ineedyourdiddly
The Following 7 Users Say Thank You to strat61caster For This Useful Post:
Cybmx (07-26-2016), GeorgeJFrick (06-29-2017), gramicci101 (07-26-2016), Infinity (07-27-2016), Plumbus (08-10-2020), Strife26 (04-24-2017), VerusEric (07-26-2016)
Old 07-27-2016, 08:41 AM   #22
Cybmx
Thanks for the detail explanation!
Old 07-27-2016, 08:48 AM   #23
Cybmx
Well, I installed the velox camber plates this past weekend, alone with koni shocks and eibach springs which lowered the car about 1-1.5". I had the camber plates adjusted all the way in for max camber, only to discover that will result in the top end link studs rubbing the frame and binding in turning. I had to dial the camber back a little untill the end links clear the frame, and I ended up only gaining a little bit of camber
Anyone have any suggestions on how I can get more camber? I did a search and only found one similar case like mine, and the person hammered the frame in a little. Don't think that I want to do that..
Old 07-27-2016, 10:59 AM   #24
strat61caster
Camber bolts.
Option 1: OE camber bolt is a small (14mm) bolt in the upper hole to replace the big one, push hub in, tighten, bit sloppy but cheap and legal for certain classification systems
Option 2: Look up camber bolts, every company sells you a 16mm eccentric bolt for the upper hole, this works, I got about an extra -1 degree out of it. I believe more adjustability comes from buying a 14mm eccentric bolt and putting it in the lower hole then taking the bolt that was in the lower hole and putting it in the upper hole. You can also buy both eccentric bolts and install both.
http://www.spcalignment.com/index.ph...tion&pid=81280
http://www.spcalignment.com/index.ph...tion&pid=81260
http://www.ft86club.com/forums/showthread.php?t=18865
ineedyourdiddly
Old 07-27-2016, 11:39 AM   #25
Cybmx
Camber bolts.
Thanks. I have the bolts in the lower spot already, will try putting another set in the top too. My tires are already very close to the strut however, so I'm worrying the camber bolts on top might result in rubbing.
Old 07-27-2016, 11:46 AM   #26
gramicci101
Off Topic
What wheels and tires are you running?
Old 07-27-2016, 11:49 AM   #27
Cybmx
225/45/17 on 17x9 et 35. Will switch to 245/40/17 next set
Old 07-27-2016, 12:05 PM   #28
gramicci101
Off Topic
With a 17x9+35 you shouldn't have too much of a problem clearing the spring perch. I know people running 17x9+42 that were ok before they switched to coils for performance reasons. Dial in what camber you can from the plate, and get the rest from camber bolts.
The Following User Says Thank You to gramicci101 For This Useful Post:
Cybmx (07-27-2016)
FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch dp1 Brakes, Suspension, Chassis 7 05-01-2016 10:28 PM
FS: Raceseng Cascam Camber Plates bombardius Brakes, Suspension, Chassis 0 04-12-2016 06:55 PM
FS: Raceseng Camber Plates (for KW/Tarmac coilovers) Sportsguy83 Brakes, Suspension, Chassis 2 01-21-2015 04:24 PM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 05:34 PM
F/S: Raceseng Front Camber Plates ExxelDistributions Brakes, Suspension, Chassis 6 10-25-2014 03:02 PM
