Drives: 2014 SWP BRZ
Velox vs Raceseng Camber Plates
Been toying with the idea of adding camber plates to my car. The -1.5 from camber bolts just isn't doing it for me anymore. I have the SPC bolt on the bottom, I know I can add the crash bolt to the upper lobe, but this isn't a route I really want to take.
Just wondering if anyone has had any experience with the Velox/ft86SF plates. I know the Raceseng plates are top notch and add caster adjustment. I just don't think I will ever adjust caster. Is the approx $300 price difference worth it if all I'm doing is adjusting camber? The car is a 1x per month autoX and maybe 2x a year track day. Thanks In Advance. |
#2 |
Drives: 2014 GT86
They both are fine.
I bought raceseng due reasons like 1) i'm buying it once, why not get something offering most, even if i don't need it right now; 2) i liked customisation options for broad range of coilovers if/when i'll switch. But 1) no caster adjustment on velox's .. that might be also good point, as one less thing to fail/stronger construction; 2) price difference really is significant enough for many, not just few dollars less. Hmm, though then again, if budget matters a lot, why not go with camber bolts & slotting struts? Go with whichever by whatever reasons matter more to you, they both should do the job and are quality products. Imho no need to go for lengthy discussion of why one may be slightly better and by what slightly worse then another. |
#3 |
Racerxfab makes front lower control arm that has camber and caster adjustment. Might be a better solution for you
Sent from my SM-G850W using Tapatalk |
#5 |
Drives: 2016 Scion FR-S
I see 2 on the Racer-X site:
http://racerxfabrication.com/frs-brz...r-control-arms http://racerxfabrication.com/frs-brz...r-control-arms One is $550, one is $680. I'd say they are both within the range of the Raceseng plates. Not sure if there would be any advantage in going for these instead of camber plates. The Raceseng plates only actually give 1 degree of positive caster over stock. I know this can be an advantage in auto-x, not sure about the track. Not really sure how much of a difference just 1 degree of positive caster actually makes, though. Both are supposed to be great quality, but the Raceseng is basically twice the price. I would say the only reason the Raceseng may be worth it to you is because you are doing monthly auto-x events. Assuming you care about competing, not just going for fun, etc. |
| The Following User Says Thank You to Infinity For This Useful Post: | bhmax (06-22-2021) |
#6 |
Im going to to do plates over Front LCA because I like having the adjustability. I would like front camber to be around -2 for Daily Driving and bump it up to around -3 on autocross days. Plates are quick and easy to adjust.
Its not about being competitive, I'm not on that level. I just want the car to behave the way I want it to when doing runs. I will probably get the Raceseng plates. I don't need caster adjustment now, but maybe later. Im all about having something I can grow into and doing it right the first time. I make my purchase next month and check back in to let ya know which one I went with. Along with a review. Thanks Everyone. |
#7 | |
You'd be better off with -3* of camber and zero front toe than -2* and some toe for daily driving tire wear.
#8 |
Drives: '13 FRS - STX
IMO the big advantage to Raceseng is adaptability to different suspension packages.
If you're not planning on changing dampers or spring sizes in the future save the $$$ and try the Velox. |
#9 |
Drives: 2014 GT86
Well, Velox's has listed compatibility with B6/8/14/16 Bilsteins, V1/3 KWs, RCE Zero &2, stock, ST, Konis Yellow, so imho versatility wise Velox camplates are fine too.
#10 |
I can't speak to Velox but have ran Eibach's that were integrated to my R2s and Raceseng's. Camber is super important on the FRS/BRZ, that alone is likely worth the difference. Raceseng's quality is top notch, all the component parts are of the highest grade. If you want a total solution, Raceseng is the way to go. If you're budget conscious, I'm sure the Velox ones will do enough for the money.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following User Says Thank You to swift996 For This Useful Post: | ChrisSC300 (06-29-2016) |
#11 |
Drives: Subaru BRZ / Toyota 86 Experts
#12 | |
| The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post: | ChrisSC300 (06-28-2016), Racecomp Engineering (06-28-2016) |
#13 |
#14 |
No, not at all. It's camber that's the most important for the front struts, big improvements to grip during cornering will be found as you move past 2.5 degrees.
He may have been talking about caster, but I will take the ideal amount of camber over the ideal amount of caster any day of the week. |
| FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch | dp1 | Brakes, Suspension, Chassis | 7 | 05-01-2016 11:28 PM |
| FS: Raceseng Cascam Camber Plates | bombardius | Brakes, Suspension, Chassis | 0 | 04-12-2016 07:55 PM |
| FS: Raceseng Camber Plates (for KW/Tarmac coilovers) | Sportsguy83 | Brakes, Suspension, Chassis | 2 | 01-21-2015 05:24 PM |
| HVT vs Raceseng Caster Camber Plates? | Phaedrus29 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 40 | 12-22-2014 06:34 PM |
| F/S: Raceseng Front Camber Plates | ExxelDistributions | Brakes, Suspension, Chassis | 6 | 10-25-2014 04:02 PM |
