Old 05-12-2016, 11:20 AM   #15
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
So, I sent this next pic to my son, and he thought that the brackets would block out needed air flow
snuff58 is offline   Reply With Quote
Old 05-12-2016, 11:22 AM   #16
snuff58
snuff58's Avatar
So, I took it all off and trimmed down my brackets! This pic also shows one of the Setrab brackets, which allow the cooler to be rubber mounted, top and bottom.
Old 05-12-2016, 11:24 AM   #17
snuff58
snuff58's Avatar
and, mounted again
Old 05-12-2016, 11:26 AM   #18
snuff58
snuff58's Avatar
Sorry, no pics of me making my own hoses! I mocked the hoses in position to find the best routing, then cut the hoses and attached the ends.
Here is a view above the cooler:
Old 05-12-2016, 11:27 AM   #19
yberther
yberther's Avatar
Drives: '13 SWP Limited
Are you going to stabilize it at the bottom or planning on leaving it cantilevered off the crash beam?
Black brackets would help it blend back in! But they look better after the modifications.
yberther is offline   Reply With Quote
Old 05-12-2016, 11:28 AM   #20
snuff58
snuff58's Avatar
And a view of my installed sandwich plate with hoses connected. The yellow fitting coming out of the right side of the plate is for my AEM oil pressure gauge sensor.
Old 05-12-2016, 11:31 AM   #21
snuff58
snuff58's Avatar
Hmm. With the open grill, my new cooler is susceptible to rocks and stones!
I went to Home Depot and bought a single piece of rain gutter cover / expanded metal. I painted it flat black and wire-tied it to the back of the opening in the bumper:
Old 05-12-2016, 11:37 AM   #22
snuff58
snuff58's Avatar
DONE. (you may now comment)
All done! dramatic difference in oil temps! Total cost of all the parts: $546.26 not counting taxes or shipping charges. It is nice to be within driving distance of Summit Racing!
The Following 2 Users Say Thank You to snuff58 For This Useful Post:
Cole (05-12-2016), Guff (05-12-2016)
Old 05-12-2016, 12:08 PM   #23
snuff58
snuff58's Avatar
First
Oh, I get it! So, like finishing FIRST. Like in a race, or something.
Old 05-12-2016, 12:23 PM   #24
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Looks good dude!
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
snuff58 (05-13-2016)
Old 05-12-2016, 01:41 PM   #25
snuff58
snuff58's Avatar
My aluminum brackets secure the cooler at top and bottom. The 4 rivnuts are solid!
Black would be nice, but I'm not concerned about esthetics!
Old 05-12-2016, 01:49 PM   #26
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Looks like a nice install.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Old 05-13-2016, 12:05 AM   #27
redlined600
redlined600's Avatar
Drives: Fr-s
Do you have a picture how you ran the lines around/under the headlight. I was trying to mock mine up with a similar placement and just didn't like how the lines went through that area.
Old 05-13-2016, 07:46 AM   #28
snuff58
snuff58's Avatar
I don't have a good pic of how I routed the hoses, but I forgot to include this one. The longer hose goes thru the foam just outside the radiator high and connects with the 45 degree fitting at the plate. The short hose goes thru several inches lower, and comes up to the plate at the 90 degree fitting on the right of the plate.
The Following User Says Thank You to snuff58 For This Useful Post:
redlined600 (05-14-2016)
FS: Setrab 19 Row Oil Cooler byun Engine, Exhaust, Bolt-Ons 24 10-16-2015 02:07 PM
*BRZ Part Out* Setrab oil cooler kit xDanger_208x Engine, Exhaust, Bolt-Ons 12 04-07-2015 08:50 AM
FS: Setrab oil cooler. Vortech V3 oil. MyRx Engine, Exhaust, Bolt-Ons 7 03-20-2015 01:23 PM
Setrab/Perrin oil cooler jack43 Engine, Exhaust, Bolt-Ons 2 11-24-2014 01:59 AM
Setrab 10 Row Oil Cooler *SOLD* Captain Snooze Australia Classifieds 0 07-08-2013 06:18 AM
