Old 05-02-2016, 03:51 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by NOHOME View Post
Pretty easy task to change an air filter. Tried to toss in a new Fram air filter and 45 minutes later had to give up and put the old one back in.
There a trick to this? Dont buy Fram products?
Are you sure you're doing it correctly?:
http://www.ft86club.com/forums/showthread.php?t=7975
I'm lucky the TRD intake is much bigger but somehow less cumbersome to mess with
Old 05-02-2016, 03:56 PM   #16
mpross
mpross's Avatar
Drives: 2015 Scion FRS
Originally Posted by Riftur View Post
My K&N took less than 5 mins to put in.
Hmmm... I dunno. It didn't drop in as cleanly as the factory one. The clips didn't want to buckle as easily. Seems to be working though
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Old 05-02-2016, 03:56 PM   #17
strat61caster
strat61caster's Avatar
Boxes confuse me sometimes, so it took me 15 minutes to get my K&N in, coming up on being due for a cleaning.
Interesting to note that the TRD is also oiled, so much for that 'oiled filters are crap and will screw up your sensors that's why OE is dry' theory...
ineedyourdiddly
The Following 6 Users Say Thank You to strat61caster For This Useful Post:
Cole (05-02-2016), FRSBRZGT86FAN (05-02-2016), Muaddib (05-03-2016), roddy (05-02-2016), soulreapersteve (05-02-2016), Tcoat (05-02-2016)
Old 05-02-2016, 03:58 PM   #18
Properly oiled is really the key factor there!
Cole (05-02-2016), finch1750 (05-03-2016)
Old 05-02-2016, 04:00 PM   #19
Riftur
Riftur's Avatar
Originally Posted by Cole View Post
I don't think this is the exact article but this is an example. I don't think it was for the FR-S.
http://forum.fdmc.org.uk/phpBB3/viewtopic.php?t=1272
Riftur is offline   Reply With Quote
Old 05-02-2016, 04:13 PM   #20
FRSBRZGT86FAN
Usually all the issues I've ever seen with "oiled" filters are involved with over oiling
Old 05-02-2016, 05:24 PM   #21
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
the trd air filters are just rebadge K&n filters, almost everything is outsourced for TRD USA
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 05-02-2016, 06:00 PM   #22
Riftur
Riftur's Avatar
Strange, mine slid in nice and snug, clips buckled on perfectly. I dont think it would go in the wrong way so it must be right. weird.
Old 05-02-2016, 06:34 PM   #23
Talking filters here not your last date!
Old 05-02-2016, 07:03 PM   #24
humfrz
Boxes confuse me sometimes, so it took me 15 minutes to get my K&N in, ...
You're supposed to take it out of the box first, ....... before you put it in .......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
finch1750 (05-03-2016), strat61caster (05-02-2016), wireman957 (05-02-2016)
Old 05-02-2016, 07:07 PM   #25
humfrz
What's with the "clips" ...... have I been missing something .......
humfrz
Old 05-02-2016, 07:08 PM   #26
Elkton86er
Elkton86er's Avatar
Drives: 2014 Subaru BRZ Limited WRB AT
I had trouble with mine too, and after several attempts I found that the "trick" is to place the new filter on the bumper (fixed) side of the housing and then clip the box (moving) side around it. This was MUCH easier than what I was doing (which was to place the new filter in the box side and clip it with filter on to the other side).
To repeat - try placing the filter on the fixed frame and then clipping the box around it. Hope this helps.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips
Elkton86er is offline   Reply With Quote
The Following User Says Thank You to Elkton86er For This Useful Post:
GoobyFRS (05-03-2016)
Old 05-02-2016, 07:18 PM   #27
Riftur
Riftur's Avatar
lol well both are true lol
Old 05-02-2016, 07:29 PM   #28
8R6
8R6's Avatar
Drives: FRS
i have an HKS drop in filter. fit perfectly and the whole thing took under 5 min. i spent more time unscrewing the bolts than swapping the actual filter.
8R6 is offline   Reply With Quote
SOLD: LED lights, Stivo duckbill, clear corners, engraved plate fram CaptainSlow Exterior Parts (Aero, Lighting, Etc.) 16 12-18-2015 01:59 PM
Cusco Oil Filter or Blitz Oil Filter Mr.Impreza CANADA 6 10-11-2014 07:08 AM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
FRAM CA9482 Airfilter louder? Pake1 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 01-19-2013 07:55 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
