Old 08-23-2016, 06:32 PM   #15
armstrom
Drives: none
This is a fairly common problem with turbo cars in general. To understand why you first must fully understand all the pressures/forces involved in making your wastegate function. Most people think boost pressure vs actuator spring force is all that's going on... But that's only half the story. You also have to consider the force applied to the wastegate valve/flap by the back pressure in your exhaust manifold. The actuator spring will open the wastegate when the sum of these two forces exceeds the spring force.
When you increase the flow capacity of your exhaust system you decrease the pressure on the wastegate valve, meaning more boost pressure is required to reach the same net force required to compress the spring... So your boost creeps.
The only way to remedy this condition is with a lighter actuator spring. Or, I suppose, going back to a more restrictive exhaust, but who wants that? ☺️
Sent from my XT1095 using Tapatalk
armstrom is offline   Reply With Quote
The Following User Says Thank You to armstrom For This Useful Post:
COO86L (08-26-2016)
Old 08-26-2016, 11:15 AM   #16
FA5teryo
Drives: GT3076r 8th gen Si
ran a 4psi spring and it never had probz. much better bewst controlz.
FA5teryo is offline   Reply With Quote
Old 08-26-2016, 01:32 PM   #17
armstrom
Drives: none
Too light of a spring can also cause problems of being unable to reach your target boost. This is more commonly a problem with standard internal wastegate actuators. External wastegates typically have two ports that allow you to hold higher boost even with a light spring (some internal actuators do as well, but very few)
-Matt
Boost Creep? #maverick# Forced Induction 14 08-20-2015 10:46 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
Does anyone else's headrests creep upwards as they drive? Silver Ignition Scion FR-S / Toyota 86 GT86 General Forum 19 03-26-2014 01:35 AM
Boost creep Djen Forced Induction 58 08-24-2013 04:49 PM
