Old 04-20-2016, 06:14 PM   #15
DeviantBlue
I know we are throwing out obvious things here but have you checked the fuses? I can not believe for one second that both actuators went for a shit.
I haven't checked the fuses yet. I'll do that when I get home from work. I'd like that to be the solution since it would be an easy fix. Thanks for pointing out the obvious haha.
DeviantBlue is offline   Reply With Quote
Old 04-20-2016, 06:35 PM   #16
LOL That is why I mentioned it. It will never cease to amaze me how many people don't start with fuses when they have an electrical problem.
Fuse is in the box in the engine compartment. Fuse number 24. See page 276 of the manual for the diagram. You can pull the manual up here if you don't have it handy: http://m.scion.ca/scion/en/m/owners/manuals
Now if a fuse that is only half the battle because if it blows again then you need to figure out why (Once can just be a bad fuse. Twice means there is a problem for sure)
DeviantBlue (04-20-2016), humfrz (04-20-2016)
Old 04-21-2016, 12:44 AM   #17
DeviantBlue
So I just checked fuse #24 (power door lock) but the fuse is not blown. I even replaced fuse #24 with a spare fuse just to make sure. Any other advice?
I appreciate the detailed instructions btw.
Old 07-12-2016, 12:52 PM   #18
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
Did you ever fix it? I have the same issue and I definitely think its the door lock actuator. My driver side is the worst...the passenger i think is holding up.
http://www.ft86club.com/forums/showp...6&postcount=18
Kayysonie is offline   Reply With Quote
Old 07-12-2016, 12:55 PM   #19
STV3
Señor Member
STV3's Avatar
See if the unlock button on the door will activate the lock. I had my drivers side lock stop working for both the key fob and actual button on the door. Got it replaced under warranty
STV3 is offline   Reply With Quote
Old 06-05-2018, 12:20 AM   #20
DeviantBlue
The door actuators had be be replaced. They are fixed now.
Old 06-05-2018, 01:25 AM   #21
Impureclient
Drives: 2015 FR-S
So both sides went out at same time?
Impureclient is offline   Reply With Quote
Old 06-05-2018, 02:23 AM   #22
DeviantBlue
Driver's side went out first then a few months later the passenger's side went out.
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 02:24 AM
Diagnosing a brake noise, need help.. Subie_Nubie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-27-2017 02:47 AM
Diagnosing low oil pressure BDotG Issues | Warranty | Recalls / TSB 6 02-29-2016 04:09 PM
Need help diagnosing engine noise and misfire Killerb92 Engine, Exhaust, Transmission 21 12-09-2015 11:14 PM
