Old 03-28-2016, 11:28 AM   #15
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
im running 400 lbs of boost on stock block. tuned on diesel fuel only though thats the key.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 03-28-2016, 11:35 AM   #16
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
This is your sick triple supercharged FWD converted setup right?
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 03-28-2016, 11:39 AM   #17
nickmerronesucks
Ned flanders
Yes I am also running the custom intake from mike brz. It generates an extra 2psi of boost while moving.
797Performance.com
Old 03-28-2016, 12:37 PM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Boost does not kill engines, Torque is what kills engines. You should be considering how much torque you will be producing and when in the power band you are making it. Too much too soon and you will bend your rods.
*gasp* hes learning lmao
Old 03-28-2016, 12:57 PM   #19
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
lmfao!! Like I said I am good for more then just fuckery I should be spending more time helping people then posting spiderman memes
Old 03-28-2016, 03:53 PM   #20
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Originally Posted by cdq85 View Post
yes, I'm pretty sure the AT was proven to hold a good bit more power actually. Way too lazy to search and find the threads about it even though I could have done it by the time I finished typing this.
Sweet good to hear
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 03-28-2016, 04:21 PM   #21
JustAnEngineer
Drives: Nissan Versa
Originally Posted by Rifle View Post
I daily 12psi(69mm pulley) on my Sprintex 210 Twin Screw.
That's with pump gas right, based on your signature?
JustAnEngineer is offline   Reply With Quote
Old 03-28-2016, 05:07 PM   #22
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
All of it
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 03-28-2016, 05:37 PM   #23
Cole
Not a troll
Cole's Avatar
Originally Posted by #maverick# View Post
All of it
Beat me to it, you son of a bitch
Old 03-28-2016, 09:52 PM   #24
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Yup.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-30-2016, 12:12 AM   #25
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
I'm running 10.5psi on pump gas, I have access to 103 Oct E85 and 120 Oct but haven't bothered to get a tune for those since they're not exactly local except the E85
-Avo @ 10.5psi-
Flashfire88 is offline   Reply With Quote
Old 04-03-2016, 03:32 PM   #26
denso
Drives: 86
What is "pump gas" at your locations? I know how americans get their octane rating (e.g. 91oct or 93oct). Im using 102ROZ (90MOZ) fuel so it should be 96 octane for you US guys.
Can you tell me a "save limit" of boost with this fuel? Im aiming for 300-350whp. Completely stock.
Edit: im using a turbocharger with following specs: 56,6mm compressor ; 56mm turbine ; .63ar turbine housing ; .70ar comp housing. T3 flange with internal wg.
It seems to be anywhere between a Gt2876 and a gt3076.
Cheers from germany
denso is offline   Reply With Quote
Old 04-03-2016, 06:52 PM   #27
Bykov
Drives: 2014 Monogram FR-S Whiteout
Cheers from germany
Pump gas is usually 91. There are a lot of stipulations to that as California 91 seems to be complete garbage (west coast) and we have 91 at high elevations which is plenty at 5000 feet while on the east they mostly have 93 which I believe should be premium everywhere but we can't all have what we want. Still, lowest common denominator is a good way to go about things so again, Ca 91 (I think) is what I would call pump gas because if your tune can survive that, you should be able to survive everywhere else.
Bykov is offline   Reply With Quote
Old 04-07-2016, 09:37 PM   #28
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
This is miss leading. Not all turbos and SC are equal. My gtx3076r will out flow the smaller trim turbos at the same psi and produce more hp.
Just keep it safe keep 7psi until you have money for a built block or suffer like the rest of the greedy peeps who don't have an engine anymore.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
What gear+rpm to experience maximum torque? SamuelDev BRZ First-Gen (2012+) — General Topics 6 11-11-2015 11:11 AM
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 11:40 AM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 08:45 PM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
