Old 03-24-2016, 11:50 AM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by rjgough95 View Post
ZA1JA01D
OFT? If so then these are what you want:
Code:
<table name="MAF Correction After Start (Neutral)" storageaddress="11C7B4">
  <table type="X Axis" storageaddress="11C768" />
  <table type="Y Axis" storageaddress="11C794" />
</table>
<table name="MAF Correction After Start (In Gear)" storageaddress="11C8B0">
  <table type="X Axis" storageaddress="11C864" />
  <table type="Y Axis" storageaddress="11C890" />
</table>
Alternatively you can find my complete OFT D series definition here.
Make sure you go back to a previously save file before making these changes, do not use the one you have recently made.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-24-2016, 12:14 PM   #16
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Code:
</table>
</table>
Yes OFT. So i can use the OFT D series gave me for my image v2.072 Stage 2 93 Oct UEL. Every time i think i am understanding this system i get screwed up. So i used what you gave me and used the image and made all the changes that i needed to. Only question i have is that the idle control also has a G, H, I. The picture doesnt show those being changed only A-F. So do i also need to make the changes to G, H, I?
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 03-24-2016, 01:02 PM   #17
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by FRSBRZGT86FAN View Post
You're question is a bit unusual, you simply do all those adjustments, I too had a berk muffler delete for some time so I quieted it down thanks to @steve99 and his instructions he clearly says you have to edit:
1)Timing
2)The agressive maf tables
3)Idle speed targets
4)DTC code P050B
5)Total Injection port ratio (optional depending on fuel but it doesn't hurt to do it anyway creates a much smoother idle)
Do all five and you will no longer have that booming cold start sound, the RPM level you mentioned is specifically controlled by coolant temperature and it will be quieter now at the normal 1400 rpm warm up portion. This is what you're tables should look like the -6.99 part can be -4 for you. The timing is adjusted due to the fact you no longer need to warm the catalytic converters up anymore as one of them are gone without the catalytic converter or without a muffler it is obnoxious and not worth having it.
What's wrong with just waking up the neighbourhood?
fumanchu1 is offline   Reply With Quote
Old 03-24-2016, 01:37 PM   #18
Kodename47
Kodename47's Avatar
Drives: UK GT86
I assume it will work with that ROM file, if all the tables look fine then you're good to go. I don't tend to keep up with OFT but if you have a recent download then you're good.
You can change G/H/I to suit like the others. I have no idea when they are used, if at all, but the tables exist.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-24-2016, 01:41 PM   #19
rjgough95
rjgough95's Avatar
I noticed that under ALPHA BRZ there arnt all the tabs there like the others i have used only thing saw off to me. Thanks for the help!!!!!!
Old 03-24-2016, 01:53 PM   #20
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, I organised mine a little differently. By the time I was doing it, most of the Alpha tables were proven to work. If you have a look about it's fairly easy to determine where things are
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-24-2016, 02:05 PM   #21
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
At 5am in the morning, they are not happy. I live in a condo unit so we are all close to each other.
Kayysonie is offline   Reply With Quote
The Following User Says Thank You to Kayysonie For This Useful Post:
fumanchu1 (03-24-2016)
Old 03-24-2016, 02:07 PM   #22
fumanchu1
I see lol makes sense i never get up before 10am so its a non issue
Sent from my SGH-M919V using Tapatalk
Old 03-24-2016, 02:57 PM   #23
mike7792
mike7792's Avatar
Drives: 2014 Scion FR-S
https://drive.google.com/file/d/0Byr...ew?usp=sharing
Here you go! To anyone else asking for me to do these just so you know I'm not going to this is and @Kayysonie are really the only ones I intended to help here
Thank you very much !
mike7792 is offline   Reply With Quote
Old 03-24-2016, 03:59 PM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Nothing, you can it's just not fun if you have a family in the house who you wake up every morning going to class or work
Old 03-24-2016, 09:01 PM   #25
steve99
ZA1JA01D and what do you mean Addresses?
As @Kodename47 said your using a definition not matched to rom , you need to use oft defs not ones from github\romraider read the romraider tips link below
Old 03-24-2016, 09:04 PM   #26
steve99
What is the safest/highest value can you go?
Thier not much difference once you get to -4 above that no real benifit normal idle is about +10 so dont go above that
Old 03-25-2016, 03:56 AM   #27
FRSBRZGT86FAN
How are the cold starts? Have you heard the difference after the car has sat for 6-8 hours?
Old 03-25-2016, 04:04 AM   #28
mike7792
mike7792's Avatar
I've been finding that it takes a really long time before it will settle at an rpm lower than 1000rpm. Something to worry about?
it does lower that initial "bark" on cold start though.
15' BRZ M/T - Cold start misfire mstoochn Issues | Warranty | Recalls / TSB 3 09-17-2015 12:13 AM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
Cold weather start oppiee CANADA 57 01-16-2015 03:20 PM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
