#15 |
Drives: 2014 SWP BRZ, MT
No large bore bearings can fit the front uprights without significant modification. I've done the research and tried. The fronts are a smaller bore and only fit the 5x100 sized bearings. 08+ STI rear bearings will bolt into the rear and fit and work (I ran them for a while) but the factory rear bearing is already the same size as the STI bearing. The STI front bearings are the same diameter as the STI rears, but that is why they will not fit.
The answer is racecar. Always.
#16 |
Any updates on the front without having to go with aftermarket uprights?
#17 | |
Drives: Toyota
https://www.facebook.com/47190581288...714172/?type=3 Anyone heard of them / used their stuff? http://www.t-demand-usa.com http://www.t-demand.jp Note - Megan/Hardrace have stopped production of their kit and advised it wont be reintroduced |
| The Following User Says Thank You to eztygr For This Useful Post: | Apex-Apex (01-04-2017) |
#18 | |
#19 | |
Drives: Toyota
I asked them if they were 'off road use only' as most of their parts are listed as this and the reply I got was 'most of our parts are for off road use only' So read into that what you will.... I read it as if a hub bearing fails and you've been driving it on the street it wont be covered under warranty |
#20 | |
#21 |
Home Builder
Drives: 2015 USDM FR-S
| Hardrace 5x114.3 Hubs | JP | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 80 | 12-11-2014 08:33 AM |
| USB Hubs / Splitters | wahsaihin | Electronics | Audio | NAV | Infotainment | 2 | 06-14-2014 02:02 PM |
| Steering Wheels and Hubs | Juurian | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 03-08-2013 10:21 PM |
| Any news on 5x114.3 front hubs for BRZ/FRS yet? | eikond | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 10-25-2012 11:10 AM |
