#15 |
Drives: White 2014 BRZ
The disadvantage of the ESC is there is NO upgrades and NO headroom. Unlike a conventional supercharger where you can change pulleys. To me the ESC feels alot like my Wrx I use to have. It's quick but nothing mind blowing.
JDL Turbo kit - Ecutek, HRI tuned.
| The Following User Says Thank You to stevo585 For This Useful Post: | DAEMANO (03-06-2016) |
#16 |
Drives: 86
Good to know it can hold boost for that long.
Indeed, a good testing ground would be the Auto Club Speedway roval... a NA twin will stay flat out for ~30 sec in the banking, and there's several long 4th-5th gear straights in the infield. The benchmark for an NA twin is 2 minutes.. with about half that time WOT. TBH at the track you'd want a traditional centrifugal supercharger for the top end power. But I can see how the ESC could be a blast in the canyons or hillclimbs. |
| The Following User Says Thank You to juliog For This Useful Post: | DAEMANO (03-06-2016) |
#17 |
The esc is great for autocross or short tight tracks.
#18 |
Drives: frs
My concern with esc is running out battery and how much time take to recharge. But i like the "hidden power" of it, makes the perfect sleeper
#19 | |
The most I ever boosted was probably 15-20 seconds which at that point your at 120+ mph at the top of 5th gear in a manual. I can tell you the recharge rate is claimed to be 8:1. Meaning a 5 second burst would take 40 seconds to recharge to max voltage. I can also say that during my quarter mile runs the system was fully charged by the time I got my timeslip.
| The Following User Says Thank You to stevo585 For This Useful Post: | Teseo (03-06-2016) |
#20 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#21 |
Well almost. A good EL header and flex fuel would be an improvement.
Like I said earlier if you look at HP calculators (which are mathematical) they range from 215-230whp if you input my 1/4 mile of 13.8 @ 101 weight of 2900lb. Tq would be around 200wtq. There much more area under the curve than peak numbers suggest. No dyno just the above math.
#22 | |
NEW CAR!🚨🏎️⛽
#23 | |
I got rid of my catback and put the stocker back on because of the noise. Its fine now wish is louder sometimes. May put a "quiet" catback on soon.
#24 |
Drives: n/a
Thanks all for the inputs. Decision seems clear now. For the time being I'm very satisfied with trd intake+OFT+OFH+trd exhaust
@DAEMANO when I got my FR-S 6 months ago I promised my wife a Gucci purse. Little did I realize how expensive they are :$ So yea, I'm hoping once that's out of the way maybe another ESC will come up Sent from my HTC One M9 using Tapatalk |
| The Following User Says Thank You to illmatic_frs For This Useful Post: | DAEMANO (03-08-2016) |
#25 | |
Drives: 2013 Firestorm FRS
| The Following 2 Users Say Thank You to continuecrushing For This Useful Post: | illmatic_frs (03-08-2016), TachyonBomb (10-24-2017) |
#26 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
13.8........peeps, that’s really slow for the kit in my opinion. There are FBO NA twins running 13.8 or 14 flat, not a big difference. If the esc ran a 13.5 or shorter, boom, different story.
#27 | |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
1) Swap a stronger electric motor w/ longer peak performance duration 2) Get a 3rd battery/upgrade to a 36V system 3) Upgrade to a 24V or 36V LiFeMnCo4 (Lithium Ion battery pack) 3.1) Get a glycol cooled Lithium battery pack 4) Install a high output generator for faster recharging 5) Lighten the turbine wheel and shaft If you want to get creative you can attach the electric motor to a gear that will increase the rpm of the turbo wheel shaft above the rpm range of the electric motor. Kind of the opposite of how tesla's car motors use a reducing gear to get their XX,000 rpm electric motors to spin the transmission/wheels at X,000 rpm. This would get an ESC motor that spins at XX,000 rpm to spin a turbo wheel up to XXX,000 rpm. |
#28 | |
The kit is more torque than anything top end is lackluster.
| Trying to find the Intercooler Kit for a Sprintex 210 or Innovate Kit. | Cross | Forced Induction | 9 | 06-11-2015 11:04 PM |
| Innovate/Sprintex Supercharger | erbaker67 | Engine, Exhaust, Bolt-Ons | 6 | 05-27-2015 08:54 PM |
| Innovate/sprintex SC | rudysaliby | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 10-28-2014 04:14 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 24 | 04-04-2014 03:38 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 5 | 03-05-2014 08:26 AM |
