Old 03-05-2016, 07:51 PM   #15
stevo585
Drives: White 2014 BRZ
The disadvantage of the ESC is there is NO upgrades and NO headroom. Unlike a conventional supercharger where you can change pulleys. To me the ESC feels alot like my Wrx I use to have. It's quick but nothing mind blowing.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 03-06-2016, 03:16 AM   #16
juliog
juliog's Avatar
Drives: 86
Good to know it can hold boost for that long.
Indeed, a good testing ground would be the Auto Club Speedway roval... a NA twin will stay flat out for ~30 sec in the banking, and there's several long 4th-5th gear straights in the infield. The benchmark for an NA twin is 2 minutes.. with about half that time WOT.
TBH at the track you'd want a traditional centrifugal supercharger for the top end power. But I can see how the ESC could be a blast in the canyons or hillclimbs.
juliog is offline   Reply With Quote
Old 03-06-2016, 08:04 PM   #17
stevo585
The esc is great for autocross or short tight tracks.
Old 03-06-2016, 08:16 PM   #18
Teseo
Drives: frs
My concern with esc is running out battery and how much time take to recharge. But i like the "hidden power" of it, makes the perfect sleeper
Old 03-06-2016, 10:24 PM   #19
stevo585
You have at least 1 minute straight of boost. Which is an insane amount of time for the street or anything short of a road course.
The most I ever boosted was probably 15-20 seconds which at that point your at 120+ mph at the top of 5th gear in a manual.
I can tell you the recharge rate is claimed to be 8:1. Meaning a 5 second burst would take 40 seconds to recharge to max voltage.
I can also say that during my quarter mile runs the system was fully charged by the time I got my timeslip.
Old 03-06-2016, 11:21 PM   #20
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
You have a theoretical best setup for the ESC, header, FP, E85 custom tune etc. Do you have any dyno numbers with that setup? I would be interested to see
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 03-07-2016, 04:37 PM   #21
stevo585
Well almost. A good EL header and flex fuel would be an improvement.
Like I said earlier if you look at HP calculators (which are mathematical) they range from 215-230whp if you input my 1/4 mile of 13.8 @ 101 weight of 2900lb. Tq would be around 200wtq. There much more area under the curve than peak numbers suggest.
No dyno just the above math.
Old 03-07-2016, 09:33 PM   #22
Aztec
Aztec's Avatar
I've seen those numbers with similar builds. I'm still on the fence whether or not I should replace the OEM OP, FP. I don't really want the extra noise since I already am running the header and I'm sure the gains are fairly minimal
NEW CAR!🚨🏎️⛽
Old 03-07-2016, 10:35 PM   #23
stevo585
I just have a catless header and catless front pipe. Those are the two with most gains because of the cats. The OP doesn't do much neither does a catback until your making big power.
I got rid of my catback and put the stocker back on because of the noise. Its fine now wish is louder sometimes. May put a "quiet" catback on soon.
Old 03-08-2016, 12:16 AM   #24
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
Thanks all for the inputs. Decision seems clear now. For the time being I'm very satisfied with trd intake+OFT+OFH+trd exhaust
@DAEMANO when I got my FR-S 6 months ago I promised my wife a Gucci purse. Little did I realize how expensive they are :$
So yea, I'm hoping once that's out of the way maybe another ESC will come up
Sent from my HTC One M9 using Tapatalk
illmatic_frs is offline   Reply With Quote
Old 03-08-2016, 07:32 PM   #25
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
there's some pretty legit clones out there lol...
Old 10-24-2017, 02:13 AM   #26
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
13.8........peeps, that’s really slow for the kit in my opinion. There are FBO NA twins running 13.8 or 14 flat, not a big difference. If the esc ran a 13.5 or shorter, boom, different story.
Dr. BRZ is offline   Reply With Quote
Old 10-24-2017, 04:14 PM   #27
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
There is plenty you can do to upgrade an ESC.
1) Swap a stronger electric motor w/ longer peak performance duration
2) Get a 3rd battery/upgrade to a 36V system
3) Upgrade to a 24V or 36V LiFeMnCo4 (Lithium Ion battery pack)
3.1) Get a glycol cooled Lithium battery pack
4) Install a high output generator for faster recharging
5) Lighten the turbine wheel and shaft
If you want to get creative you can attach the electric motor to a gear that will increase the rpm of the turbo wheel shaft above the rpm range of the electric motor. Kind of the opposite of how tesla's car motors use a reducing gear to get their XX,000 rpm electric motors to spin the transmission/wheels at X,000 rpm. This would get an ESC motor that spins at XX,000 rpm to spin a turbo wheel up to XXX,000 rpm.
TachyonBomb is offline   Reply With Quote
Old 10-24-2017, 10:10 PM   #28
stevo585
Yes but not at that trap speed. I was 97 NA on e85. Sure I can run drag radials and dump the clutch but I don't wanna lol.
The kit is more torque than anything top end is lackluster.
Trying to find the Intercooler Kit for a Sprintex 210 or Innovate Kit. Cross Forced Induction 9 06-11-2015 10:04 PM
Innovate/Sprintex Supercharger erbaker67 Engine, Exhaust, Bolt-Ons 6 05-27-2015 07:54 PM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
