Old 02-23-2016, 01:55 PM   #15
DAEMANO
Time Traveller
Originally Posted by MGPAX View Post
Wow! I've found Three places in two years. A Thortons up I 40 at 119 and one out in Smyrna which is out half the time. And the one that sells petrol with an E85 sticker on the pump (apparently). Thortons was 1.70 or so last time I fueled up there.
How do you find them? All my internet searches come up with just 3? I'm on exit 59 and I 24.
http://www.etcleanfuels.org/refuel-tn.html
http://www.e85locator.net/State%20Pa...locations.html
Old 02-23-2016, 08:19 PM   #16
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
There is another station in the Hermitage, and another one next to the airport. Not sure exactly how many there are but there are more than 3 for sure. There's one up in Gallatin, two in Lebanon, one in Murfreesboro (I think).
The one on 109 & I 40 is consistently 78-79% E.
I do have flex fuel though so I never think about it. I've seen as low as low 60's in E content.
xsnapshot is offline   Reply With Quote
Old 02-23-2016, 09:45 PM   #17
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
That first link of Daemano's shows more than I've ever been able to find online. Thanks.
BTW....Went back to that Shell that I got the bad gas from and apparently they had switched the pump to "Pure fuel" 87 no ethanol without taking off the "E85" Sticker that was just above the pump handle!! Grrrrrr. Probably the worst scenario I could imagine for an Ethanol Tune! No ethanol and 87 octane!!!
I wanted to go inside and raise hell....But probably not that guys fault.
Hope I didn't hurt my engine.
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
MGPAX is offline   Reply With Quote
Old 02-23-2016, 10:52 PM   #18
steve99
The ecu is very good at managing knock and fueling
Here is a log from a stock car running stock tune in South Africa the best fuel they can get in that country is 95 R0N, it about as good as USA 89\87. This guy has been tracking his car as well as do his mates. Its not blown up and all the other 86\brz in that country will be same. Note his iam is 0.2 and he is still getting knock corrections of -3 degrees each time throttle is opened, this was a road log
http://datazap.me/u/steve99/south-af...0&data=2-20-28
its got 30% or more fueling adjustment through trims
FLKC can drop timing instantly about 6 degrees and IAM reduction from one down to 0 can drop the timing in the mid to upper rpm ranges another 4 to 6 degrees. Thats a total of over 10 degrees mid to upper rpm, this is about the timing added in an e85 tune. While this is not ideal on an NA motor its good enough to save you in your situation unless you took it a track and beat on it.
Boosted well it probably wouldnt be pretty.
Old 02-23-2016, 11:27 PM   #19
MGPAX
Still 17!
MGPAX's Avatar
Thanks for the reassurance Steve! Mine was at -28 LTFT and .03 adv. multiplier with FLKC pulling 4 or so also.
It's good to know the car was handling it.....And I'm glad I checked it!!
Old 02-24-2016, 09:35 PM   #20
perryair
junior mafia
Drives: ‘20 sti limited
if youre ever in east nashville theres a speedway at cahal and gallatin and their e85 is always priced under regular.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 02-24-2016, 10:04 PM   #21
babydriver
Hit the road and I'm gone
babydriver's Avatar
What a bunch of fucking morons!
Slip, slidin' away.
Old 02-25-2016, 08:38 AM   #22
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
And this is why you get a Flexfuel kit and tune when going E85...
Old 02-25-2016, 02:24 PM   #23
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i didnt know we can set alert from OFT. i am going to try later
Old 02-25-2016, 03:34 PM   #24
DAEMANO
Time Traveller
Yep, works like a charm.
BTW, I've been running e85 on OFT tune stock (no flex fuel kit or ECUtek tune needed) for maybe 2 years total for about 20k miles. No problems whatsoever. Just had to be the littlest bit mindful that the right gas is going in the car. No big whoop. My buddy @WRB5titch on the board has run the same setup as I for 50k miles. Same great results. For my current setup it's terrific. I'd consider spending the extra $1500 if it was necessary, but so far, it ain't.
Old 02-27-2016, 10:22 PM   #25
WRB5titch
Drives: WRBrz
Originally Posted by DAEMANO View Post
...50k miles...
60k now
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 02-27-2016, 10:37 PM   #26
Sportsguy83
Drives: Limited BRZ
How do you go to extra $1500?
FF kit, is less than $500 from Moto East.
FF tune + Ecutek license is about $600. (Total between both about $1100).
Subtract the $400+ from OFT, and it's around $700 more.
The peace of mind if priceless
Old 03-11-2016, 07:41 PM   #27
nunonuna
nunonuna's Avatar
@MGPAX @xsnapshot
Do you guys experience knock over -1 at sudden throttle change?
Also what mods are you guys running?
I tried e85 last fall before it gets too cold, but I noticed -0.6 fbkc around 4k rpm almost every time and over -1 fbkc at sudden throttle change.
The gas I put was always e75(BP @ corner of Moores Ln & Mallory Ln in Franklin)
nunonuna is offline   Reply With Quote
Old 03-11-2016, 08:51 PM   #28
FRS Justin
Drives: 2013 Asphalt FRS
I'm on a tried and true E85 tune with Wayno's charts and maf. Worked fine for a month or so.
I fueled up at a new station (Very nice part of town) the other day.
And for the past few days I've noticed a lot of bogging. To the point I was manually downshifting to get power.
Plugged the OFT in this morning to check out what was going on:
http://datazap.me/u/mgpaxman/e85-gon...ata=7-10-11-12 (Pick any section)
After some panic, and with a half tank of fuel still I decided the numbers pointed toward some E20 or something instead of E85. And decided the best course of action was to fuel up with 93 and switch over to a Petrol tune.
http://datazap.me/u/mgpaxman/petro-t...zoom=3577-4684
So I guessed right.
Still need to go back to that station and ask them if they have any idea what they are selling!
Pax
you need a tester so you never get hung up like that again. 20 bucks and 30 seconds can save you some heart ache. one drop of food coloring really helps you read the gauge.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
HELP! WRONG GAS IN CAR nabil_frs Issues | Warranty | Recalls / TSB 85 04-01-2014 01:44 AM
This must be wrong... Ongor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-23-2014 11:29 AM
What's wrong with this car? Suberman CANADA 41 01-14-2014 12:35 PM
HELP! WRONG GAS IN CAR nabil_frs CANADA 9 05-06-2013 03:49 PM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 07:36 PM
