#15 | |
Drives: FR-S, NA8, S13
i was saying grinding/cutting of stock studs so you can use a small enough spacer to not have to use +100 offset wheels. 25mm+ usually are the thick enough spacers that will cover stock studs to be able to fit a solid back pad wheel. youd have to trim the stock studs so you can run the 10mm conversion spacer and still fit relatively okay offset wheels that would either have concave or baby lip instead of flat and none... |
#16 |
Not to mention vendors in here, but I was just browsing Bulletproof's site and they have this conversion kit forsale:
http://www.bulletproofautomotive.com...il.php?ID=7481, $500+ to do all four wheels, from Project KICS. |
#17 |
Drives: Ae86, gts86 (coming)
Thanks guys good info.
| HID Conversion DIY | loong | DIY (Do-It-Yourself) Guides | 55 | 06-27-2014 07:27 PM |
| leather seat conversion | stalon320 | Interior Parts (Incl. Lighting) | 6 | 07-20-2012 05:36 PM |
| BRZ HIDs vs FR-S HID Conversion | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 06-28-2012 06:20 PM |
| LED Conversion | [M] | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 06-18-2012 09:44 PM |
