Old 06-28-2012, 09:33 AM   #15
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
Something i noticed was when you enter the FRS forum, the first thing you see is at least 3 threads about car problems. When you go to the BRZ forum, this problem is nearly non-existent.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 06-28-2012, 09:38 AM   #16
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by eriktherod View Post
If it's not a simple fuse, your ABS module may be fried (defective). I've seen a few cars (typically Fords and Buicks) with the ABS light on and had to do with electronics.
Pull the code, give us the code, then make a diagnostic
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-28-2012, 09:47 AM   #17
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Maybe because the ratio of FRS to BRZ is somewhere around 3:1 right now?
Memphis is offline   Reply With Quote
The Following 9 Users Say Thank You to Memphis For This Useful Post:
adprokid (06-28-2012), Asterisked Accolade (06-28-2012), Ben Stef (11-08-2012), enjoi23 (08-21-2012), HotLeopardMama (06-29-2012), Linseal (06-28-2012), lucchesi423 (07-03-2012), RRnold (06-28-2012), sdlynx (08-09-2012)
Old 06-28-2012, 09:49 AM   #18
df.dima
Drives: FR-S and Mazda 3 Sky
Larger sample size?
df.dima is offline   Reply With Quote
Old 06-28-2012, 09:52 AM   #19
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
My CEL came on at about 300 miles. The code I got was "loss of communication between the ECU and the display," probably caused by my using a poorly-shielded OBD2 reader next to a high-voltage power line.
b.e is offline   Reply With Quote
Old 06-28-2012, 09:57 AM   #20
ahausheer
Re-member
Drives: Toyota camry
there is a small sensor on each wheel for the ABS. it may have fallen off? Not sure how much you know about this type of thing but its a quick visual check.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-28-2012, 11:07 AM   #21
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
...At these times I'm glad I spent $50 years ago to buy a scantool.
86'd is offline   Reply With Quote
The Following User Says Thank You to 86'd For This Useful Post:
eriktherod (06-28-2012)
Old 06-28-2012, 11:16 AM   #22
danthedirt
Hadouken
danthedirt's Avatar
Drives: Whiteout FR-S
Just finished dropping the car if with the service department where I bought her. I guess since the car is so new they have to pull the codes and report it back to corporate. Then corporate will tell them what to do. I'm waiting to find what they say. I'm hoping it's something as simple as a sensor issue.
Whiteout MT
Car Blog: downrightfrs.blogspot.com/
danthedirt is offline   Reply With Quote
The Following User Says Thank You to danthedirt For This Useful Post:
Sigh-on-Rice (06-28-2012)
Old 06-28-2012, 11:26 AM   #23
excited86
Drives: none
I am sorta happy to see we have such dedicated members to report problems. The quicker we identify these issues, we will less likely to have to pay for it when the warranty is over.
excited86 is offline   Reply With Quote
The Following 4 Users Say Thank You to excited86 For This Useful Post:
ahausheer (06-28-2012), Dadhawk (06-28-2012), HotLeopardMama (06-29-2012), russv (06-28-2012)
Old 06-28-2012, 01:00 PM   #24
danthedirt
Hadouken
danthedirt's Avatar
The anticipation of finding out what was wrong with my car was killing me so I walked into the service bay to find out what was going on. Walked up on 5 tech's standing around my car, which in my experience isn't a good sign. In talking with the tech they said that the code they pulled off was related to a crank shaft position sensor error. They all seemed to agree that they didn't think that's what the issue is. Could be the sensor or an issue with the ECU. Leaving her here so they can continue troubleshooting the issue. they said the demo car they have ran into the same issue and another scion dealership in the area had a FRS which had the same issue as well which they are going to cross reference. I'll update this thread when I get more info
Whiteout MT
The Following 2 Users Say Thank You to danthedirt For This Useful Post:
M&M_Hwy9 (06-28-2012), Sigh-on-Rice (06-28-2012)
Old 06-28-2012, 01:06 PM   #25
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
I've been reading about mostly FR-S related issues but issues that were seen on previous Subaru models; condensation, vibration in the vents etc
Wow, that sucks! Keep us posted on what the issue actually is!
Old 06-28-2012, 01:16 PM   #26
Lonewolf
Lonewolf's Avatar
Drives: Moped
This is starting to sound like what happened to whiteout and Stu....
Old 06-28-2012, 01:26 PM   #27
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
This.
I hope "corporate" has a damn good answer!
Old 06-28-2012, 01:34 PM   #28
yayforaddison
yayforaddison's Avatar
The crank shaft position sensor sounds like the same issue some of the others are also having with the idle issue. Have you happened to notice any strange idle dip? Does your idle ever randomly drop below 400rpm? Would love to know if this is all related to this little sensor, or even the crank shaft itself.
yayforaddison is offline   Reply With Quote
My car is in and still 1,304 miles away! joshua BRZ First-Gen (2012+) — General Topics 16 06-28-2012 08:02 PM
Some Miles White_OUT_FR-S Scion FR-S / Toyota 86 GT86 General Forum 0 06-22-2012 02:00 PM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
Check Engine Light directly after pickup Stu L Tissimus BRZ First-Gen (2012+) — General Topics 27 06-15-2012 05:07 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
