Old 06-28-2012, 10:23 PM   #15
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Originally Posted by mike2100 View Post
why?
If they have a gain of 10hp then why not? Its super cheap. Im going to install a A/F gauge to be on the safe side.
WolfsFang is offline   Reply With Quote
Old 06-28-2012, 10:47 PM   #16
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Keep on mind that the stoichiometric ratio for gasoline (14.7:1) is different than that of E85 (9.8:1) remember this when you are watching your wideband, you will be blending the two so a safe AFR ratio would probably be in the 11's to avoid detonation.
P.S. when I run full E85 in the Evo I have it set to 7.4:1 AFR after peak torque to give you an idea.
jedibow is offline   Reply With Quote
Old 06-29-2012, 05:51 PM   #17
WolfsFang
Scrape Master
WolfsFang's Avatar
Thanks for the info!
Old 06-29-2012, 06:00 PM   #18
slow_frs
Drives: turbo scion tc
Yes you wanna aim for 11 for AFR in a booste car, n/a cars run 13 at wot but for this at aim for 12.0 or slightly lower, anyways don't top your tank with 93 then add 1.5 that's over filling, you want to add 1.5 then top off with full tank of 93 this way you don't over fill
slow_frs is offline   Reply With Quote
Old 06-29-2012, 08:06 PM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Making fuel out of corn... just not a fan. It's neat to see people experimenting with other fuels though. I wonder what a tank of toluene and some ecu tuning would yield.
Old 06-29-2012, 10:30 PM   #20
WolfsFang
Scrape Master
WolfsFang's Avatar
You do know E85 makes greater HP/TQ then any gas you can buy from any station right?
Old 06-29-2012, 11:09 PM   #21
rice_classic
My dislike of E85 has nothing to do with the power it makes. Think political, economical and environment. Not a fan of corn.
Old 06-29-2012, 11:23 PM   #22
WolfsFang
Scrape Master
WolfsFang's Avatar
I could care less if it was made from the tears of gingers, its a great fuel type and its super cheap, around a dollar a gallon (north NJ.)
Old 06-29-2012, 11:27 PM   #23
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Dynapacks read on the high side because the car doesn't have the wheels on. Also the ramp rate effects the power numbers but as long as you are looking at the delta it really doesn't matter what the baseline numbers are.
Element Tuning is offline   Reply With Quote
Old 06-29-2012, 11:29 PM   #24
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Use the corn for alcohol, then use what's left to make corn flakes. Ain't nothin' wrong with that. But a lot of ethanol kickbacks expire this year. May be a bit harder to find that stuff.
Coheed is offline   Reply With Quote
Old 06-30-2012, 08:34 PM   #25
rice_classic
Well at least you have the right attitude.
All joking and sarcasm aside, even though it's cheap at the pump it's worth doing a little research on the "scam" that is corn ethanol.
Old 06-30-2012, 10:13 PM   #26
serialk11r
Drives: '06 AM V8V Coupe
Scam? If the government subsidizes it so it's cheaper for me to buy, that's a good buy in my book. I mean, as young people we aren't really getting like, Social Security benefits and stuff, and most of us probably aren't getting lots of benefits from earmarks or corruption, so why not take advantage of this little subsidy. It's going to be there whether or not people buy E85, and if they decide to pull the subsidy and it's not cost effective anymore, just stop running it. The farmer unions have the say on it, it's not like you can do anything about it.
Old 07-01-2012, 03:29 PM   #27
rice_classic
Like I said, you need to do your own research and after such your opinions may mirror or differ from mine but please, dig deeper.
Old 07-07-2012, 05:40 AM   #28
Allch Chcar
Drives: N/A
Originally Posted by dwx View Post
The numbers are all about the before and after. They made 180whp bone stock so they saw about a 10whp increase over stock. When you look at whp % gained it's about the same increase nameless got with their axleback. The e85 was to boost the octane a little since they seem to be in CA where they have 91 at the pump. If you have 93 already then there would be no point.
I'll add I'm not sure why their base numbers are so high, the video they posted shows the TCF set to 1.0 which I know is a multiplier on the Dynapack. Maybe the pulls were being done in the wrong gear.
That's closer to what I would expect, especially since it's compared to 91 octane. But it's still more than I would expect with full strength E85. :-/
I know you mean the true AFR but that's going to confuse people. The wideband values, which are derived from the Lambda scale, are almost exactly the same range, aren't they?
The 51 cent a gallon blender credit expired in December, BTW. You and I have a differing opinion on why it's acceptable to subsidize. I prefer the reasoning that it encourages energy independence even if it does have a high price.
And why you no mention this thread to me Cereal?
I think you'll find the truth is somewhere in between. I keep up on this stuff as much as I can and I've found Corn ethanol to be better than most of the alternatives. It's certainly not without it's costs but the most popular counters to Corn Ethanol use tend to be the most worthless.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
