Old 03-28-2016, 02:06 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by merdok12 View Post
Looking to get a Berk axel-back muffler delete. Debating on going single or dual.
Single is a lot easier to put on and off, but dual looks nicer.
From personal experience, does anyone know if one is louder than the other? Are there any performance differences?
Newbie to the forums; previous GTI owner.
The dual is quite loud, haven't compared it to the single exit because I no longer have it, here is a video of it on my car:
[ame="https://www.youtube.com/watch?v=mwskPf8W4TI"]exhaust clips - YouTube[/ame]
The only noticeable performance difference you'll get is 12 lbs off the rear end. But my personal review, is that it does drone quite badly in a very specific rpm range around 1800-2600 rpm, then it suddenly stops droning it sounds absolutely beautiful going full throttle or gradual acceleration and will pop and crackle at will sometimes. Also cold starts are louder than it should be unless you edit your tune to get rid of the loud cold starts (I did that and it sounded awesome on start). With respect to putting the axle-back on and off single vs dual, it's quite easy you just need a breaker bar, pb blaster and a exhaust hanger removal tool, it will take less than an hour with the rear end jacked up a bit for ease of install. Most of the time is spent removing the OEM muffler, that will take the largest portion of time.
Old 08-08-2016, 01:31 PM   #16
jmastrobuono
jmastrobuono's Avatar
Drives: 2016 BRZ limited
Question
That's what I was thinking. So any idea why this is $79.99 and the Berk is $199.99?
Did you end up buying the Berk? I have a 2016 also and berk won't get back to me as to if the dual tip is compatible with our cars. The website only goes to 2015 but there hasn't been any alters with the exhaust system to my knowledge..
jmastrobuono is offline   Reply With Quote
Old 08-08-2016, 01:56 PM   #17
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I got a Berk dual a couple months ago. I did the install in the parking lot of a restaurant where I met the seller. It took 5 minutes. It really is the easiest mod you can do. WD40, a screwdriver and a ratchet (I can't remember the nut size) and that's all you need.
It is loud. I have the stock header and second cat delete and it's very loud. The drone on the highway wasn't fun, so I got a cherry bomb and had it welded into the mid pipe and now there's no drone and it's only loud when I get on it.
IMHO dual looks best (I don't like an empty hole on one side of the bumper)
Old 08-09-2016, 02:25 AM   #18
FRSBRZGT86FAN
Doesn't matter any exhaust for the 13s would fit, 14 15 and 16....
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
guybo (08-09-2016)
Old 08-09-2016, 09:38 AM   #19
guybo
Huge E85 fan!
guybo's Avatar
Mine's a 16. Perfect fit.
Old 08-09-2016, 01:26 PM   #20
jmastrobuono
Thanks guys, gonna buy it now for sure!
Old 08-09-2016, 04:10 PM   #21
BRZ FTW
Drives: 2017 Subaru BRZ
any concern about underbody aerodynamics in removing that suitcase muffler? i would mostly be concerned that air at high speed would cause the rear bumper to flop around.
BRZ FTW is offline   Reply With Quote
Old 08-09-2016, 05:11 PM   #22
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
No. If it did flop around maybe a diffuser would help secure it down but i don't see that happening
berk, exhaust, muffler delete
Custom Muffler Delete vs Berk Dual Tip Muffler Delete eric2523 Engine, Exhaust, Transmission 7 07-27-2015 10:40 AM
WTS Berk Single Muffler Delete phobos512 Engine, Exhaust, Bolt-Ons 2 07-09-2015 04:06 PM
wtb berk dual muffler delete, berk catless front pipe interna Want-To-Buy Requests 1 12-15-2014 05:52 AM
WTB: Berk Dual Muffler Delete, Berk Catless Test Pipe. interna Engine, Exhaust, Bolt-Ons 0 11-26-2014 08:17 PM
WTB: Berk Dual Muffler Delete, Berk Catless Test Pipe. interna Canada Classifieds 1 11-26-2014 04:47 PM
