Old 01-26-2016, 12:41 PM   #15
DAEMANO
Time Traveller
From my research,
The Maximal Performance oil cooler kit is best bang for the buck for DD/Canyon/HDPE cars. Great components like a Mocal sandwich adapter and Setrab radiator (unlike the CX Racing's generic components), and compromises made in the right places to make it an excellent value (eg. rubber hoses instead of braided steel, etc). @Maximal will customize the kit for your specifications and works with people to create whatever is needed from top tier off the shelf components. Their build thread is here.
The Racer-X oil cooler kit could be the best overall air to oil cooler as it has an awesome custom sandwich adapter that resolves the minor fit issues of the Mocal sandwich adapter used in many of these kits, it has a top mount for the radiator (over merely mounting the radiator into the bottom plastic tray) and IMO a higher performing radiator than lets say the Mishimoto kit (the Racer-X kit can be had with larger capacity Setrab and Bell radiators like the Jackson Racing Oil cooler kit) at a price that is roughly equal to the Mishi kit depending on how you configure the kit. Their build thread is here.
IIRC the Skunk2 Ultra Radiator is the only water to oil cooler that is not Laminova (since Robispec fell off the map) that looks like it's a PITA to install, but could provide the most stable oil temps over time. @g0odspeed posted an excellent DIY that should shave time on install and component selection here.
Old 01-26-2016, 01:05 PM   #16
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Originally Posted by wbradley View Post
CX Racing. Need a ton of Teflon tape for the threaded fittings.
For a properly installed cooler, the ONLY Teflon you need AT ALL is for the NPT to AN adapters where they thread into the sandwich adapter (2X threads).
All of the rest of the fittings should be sealant free.
And I never use Teflon tape on my engines any longer.
I use the Loctite 567 liquid thread sealant.
justatroll is offline   Reply With Quote
Old 01-26-2016, 03:05 PM   #17
Maximal
Maximal's Avatar
Drives: Dodge Stealth
Originally Posted by stevo585 View Post
Does it have a thermostat?
Yep, it uses the mocal thermostatic sandwich plate.
Maximal is offline   Reply With Quote
Old 01-19-2019, 03:06 PM   #18
Sgtfluffy16
Drives: White BRZ Limited
Are there any updates to any of this? I'm looking at doing some sort of oil cooler on my car. I am supercharged, and I will be doing more hpde events this year
Sgtfluffy16 is offline   Reply With Quote
Bang for the buck - upgrades BAE Engine, Exhaust, Transmission 101 03-09-2015 08:23 AM
Best bang for my buck? ric342 Southern California 12 02-14-2015 07:09 PM
best bang for the buck HFC BlackyRose Engine, Exhaust, Transmission 11 08-25-2014 10:19 AM
Best bang-for-the-buck mods supramkivtt2jz Scion FR-S / Toyota 86 GT86 General Forum 65 04-28-2014 09:54 PM
Most bang for the buck? GIMMICK Scion FR-S / Toyota 86 GT86 General Forum 24 05-07-2013 07:10 PM
