Old 07-24-2016, 06:18 PM   #253
Blood
Drives: 2018 STI
Originally Posted by Irace86 View Post
Why run in two gears with two different tunes/fuels?
No idea. That's a question @moto-mike has to answer. But my understanding is that 4th is closest to 1:1 on AT cars, so that is the "best" for displaying actual power, though that doesn't explain why the pump gas run was in 3rd.
Blood is offline   Reply With Quote
The Following User Says Thank You to Blood For This Useful Post:
Irace86 (07-24-2016)
Old 07-24-2016, 07:06 PM   #254
Irace86
Drives: BRZ + Ducati M796
Yea thats what i thought too, that 4th gear was ideal for demonstrating power. In reality it doesnt matter for tuning, right? A tune could be done in any gear long enough to make corrections. But pick a low enough gear and the car will show inflated numbers on the dyno.
Irace86 is offline   Reply With Quote
Old 07-24-2016, 08:22 PM   #255
armstrom
Drives: none
...my understanding is that 4th is closest to 1:1 on AT cars, so that is the "best" for displaying actual power
This myth has been around since the beginning of time. It is 100% false. Some gear may or may not be "better" for getting an accurate reading on a particular car or dyno, but the gear ratio being 1:1 has nothing to do with it. The only way to couple your engine to a dyno with a 1:1 ratio is to use an engine dyno. Any chassis dyno will only be able to measure the torque after it has gone through a series of gear ratios. Yes, the transmission gear selected is the first ratio, but not the only one. Next the power goes through the final drive ratio, then if you're on a roller dyno there's the gear ratio between the tire and the roller. Let's say you're in 5th gear on a MT car (1:1 ratio) your gear ratio between the engine and your hubs is STILL 4.1:1.
Of course, any dyno worth its price measures horsepower and then uses the engine RPM to calculate torque at the engine. Since horsepower is a unit of power (force times speed) it is not multiplied by gear ratios like torque is. Of course, there are parasitic losses that we're all familiar with. Perhaps a particular gear ratio is better than another by changing the rate at which the dyno is accelerated. If the gear ratio is too high (in a low gear) then the run from ~2000-7400RPM will take very little time so the dyno will take fewer samples when calculating horsepower. This is one advantage hub dynos have over inertia dynos, you can control the acceleration rate by varying the load and stretch out the elapsed time of the pull. However you will also notice many tuners claiming they can drastically change a dyno result just by varying the ramp rate.
armstrom is offline   Reply With Quote
The Following 4 Users Say Thank You to armstrom For This Useful Post:
8686 (07-25-2016), Blood (07-24-2016), CxG (07-25-2016), Irace86 (07-24-2016)
Old 07-25-2016, 02:50 AM   #256
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
It's a bit higher, but the Cusco strut tower bar still fits. If this is the TRD one you have -- http://www.ft86club.com/forums/attac...0&d=1335026028 -- then I don't think it will fit.
Yeah I thought so. Shame I'll have to sell the TRD bar as it's a beautiful piece of hardware.
Wise is offline   Reply With Quote
Color difference between Satin White Pearl (Pre-2015) and Halo White (Post-2015)? LucidMomentum Scion FR-S / Toyota 86 GT86 General Forum 3 10-15-2014 11:29 AM
To build something better in our own self image Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 29 07-07-2014 04:56 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
looking for silhouette frs image subaruferrucci FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 01-29-2013 06:00 PM
Image resizing blalor Site Announcements / Questions / Issues 28 11-03-2012 08:46 PM
