#253 |
Drives: 2013 SWP BRZ
Can anyone confirm that their Bypass Valve is a tad loose? Noticed that when I was installing it. The little plastic line also kind of sketched me out a bit, lol. But I had some play on the actual bypass, I could move it forward and back a bit. Just want to make sure this is normal. Just remembered now about it.
I'm hoping all goes well and my JDL UEL header gets shipped this week, and then I can compare my car now then with the header. I'm still doing revisions of my map but it will be nice to see if it adds any noticeable difference. |
#254 | |
Thupercharged
![]() As long as the ATF temp stays in check
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#255 |
Done
Drives: WRB BRZ
my base map results for the day are here. we are unstrapping now so I can see what my butt dyno tells me
http://www.ft86club.com/forums/showthread.php?t=41690 |
#256 | |
NW Region Moderator
Drives: FR-S No More
| The Following User Says Thank You to DarrenDriven For This Useful Post: | NickFRS (07-16-2013) |
#257 |
AutoX-10/10ths every run
Dyno Plot
Here's a plot from one of a few runs where the car got to 205 WHP 178WTQ. Unfortunately the run where we got 216.9WHP and 178WTQ wouldn't print (doh). Anyway, you can see the smoothness of the lines here.
#258 |
I need to get a build going in my thread. I've been lazy lol.
| The Following 3 Users Say Thank You to xxscaxx For This Useful Post: |
#259 |
Drives: 2013 Black FR-S
Nice results! How much lower does that particular dyno read vs dynojet? How does she drive?
#260 |
Drives: 2013 Firestorm FR-S
I got mine installed this last weekend, finally got around to doing the initial data logs for the FA20Club tune. So far, the power delivery seems very linear, with things getting interesting around 3500rpm. Granted I have the AC on all the time because its been in the 100s lately. First set of data logs showed coolant temps maxed at 93C and oil temps of 111C (I know, its brutally hot here). Once I get the koyo radiator installed, and pick an oil cooler, I think I'll be alright. AFR is sitting at 11.02, fwiw.
Sent from...somewhere? |
#262 |
WUB WUB
Since I'm going to be doing logging on a dyno tomorrow (not messing with a 3rd gear to redline pull on the highway), I should be able to get a dyno sheet up as well. Interested in seeing how she's doing.
#263 | |
#264 |
Drives: 2013 Asphalt FR-S
A tad high on the oil, but coolent looks just fine.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#265 |
I was seeing oil temps stock of 219, highest peak of 220 prior to the s/c install.
I have yet to go over either of those two numbers with the supercharger. |
#266 | |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
