Old 10-26-2011, 07:55 AM   #253
Levi
Drives: Toyota
100 % Toyota ?
Levi is offline   Reply With Quote
Old 10-26-2011, 09:53 AM   #254
ForReal-Someday
Drives: Company Vehicle
Originally Posted by blur View Post
kinky.
what's this?
I am by no means an expert, but I believe that is the exhaust gas recirculation. It's meant to reduce carbon build up. I'm sure someone will correct me soon though.
ForReal-Someday is offline   Reply With Quote
Old 10-26-2011, 10:10 AM   #255
Matador
hashiryu
Drives: Mk4 Supra
Originally Posted by Levi View Post
100 % Toyota ?
Don't be an ass and show it.
Furthermore, this has been a cool thread thus far, let's NOT go down that rabbit hole again.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 10-26-2011, 10:18 AM   #256
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
And I'm also curious as to what that highlighted tube is.
MannyO is offline   Reply With Quote
Old 10-26-2011, 10:24 AM   #257
Tyandriel
Drives: Supra MkIII
im wondering about this tubing, too.
EGR was my first thought, too. But the EGR systems iīve seen yet were all short, near the head, small diameter and metal (because of the heat).
Second thought was vacuum for the brake booster (is it called this in english?). But seems a bit oversized and wrong positioned... Also there wouldnīt be any vacuum with the throttle closed. It hardly makes sense to keep the throttle open while braking (in normal situations).
Third thought was gas tank ventilation. But also far too big for this purpose.
What might be a reasonable purpose for intake air other than combustion?
Tyandriel is offline   Reply With Quote
Old 10-26-2011, 10:51 AM   #258
Nurburgring
Drives: S2000, AE86, RSV10000R, 911, EP91
That is not the EGR system. Itīs the air pump, most likely.
The air that is pumped by the air pump goes into the EXHAUST manifold to help complete the combustion of unburned gases during the warm up phase. This improves catalytic converter efficiency at a time when exhaust gases are quite rich. After the engine has done its initial warm up, the secondary air injection system stops working. Since it's part of the emissions system of the engine, it is monitored by the ECU.
Thanks for that pic fax0815 and Tyandriel. I hope the chassis braces are production-based and not just part of the cage used for the VLN race. It could mean they actually took chassis rigidity seriously.
Nurburgring is offline   Reply With Quote
Old 10-26-2011, 11:05 AM   #259
Tyandriel
Drives: Supra MkIII
thanks for that nice bit of info Nurburgring!
Old 10-26-2011, 12:05 PM   #260
madfast
Drives: 2010 Evo X MR-T
good explanation however, the FA20 is going to have D-4S. for cold start they most likely will follow the 2GR-FSE and use a modified stratified charge. on the 2GR, they use port injection on the intake stroke, and direct injection on the latter part of the compression stroke. not true stratified charge, but the effect is the same where the A/F mix is richer by the spark plug and leaner everywhere else. in short, i dont think such an air pump is necessary.
so what is it? i have a theory... look at this:
http://blogs.insideline.com/roadtest...-required.html
(Sorry for the giant pics)
look familiar? its from the 5.0 Mustang. it "pumps" certain frequencies into the cabin to get that great engine sound. what car also uses this? LF-A... who tuned the sound of the LF-A? yamaha. what other car did yamaha "tune"? FT...
anybody have a better explanation?
for reference this is the FB20:
madfast is offline   Reply With Quote
Old 10-26-2011, 12:19 PM   #261
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
Thats some good info. The FB20 is setup a bit different from the FT86 engine. Most obvious is alternator is front and center on the FB, off to the side on the FT. Intake goes into the front of the FT, rear of the FB.
Oil filter is in the same easy to access location. And the battery is in front of the engine in the Subaru but behind the engine in the FT (nice!).
no_name is offline   Reply With Quote
Old 10-26-2011, 12:35 PM   #262
Nurburgring
That is also a good theory madfast. Iīve seen that in Golf GTI MkVīs too. It just seemed too bulky for a "sound improver", but it could be.
In the Mustang with Coyote engine, a friend of mine removed the filter/membrane that is held in that housing shown in the second pic, and now it has a really loud intake noise in the cabin, seems to be a pretty common modification.
Old 10-26-2011, 12:41 PM   #263
Ice_Man
Ice_Man's Avatar
Drives: Toyota GT 86
Send a message via ICQ to Ice_Man
i thinke this pipe makes the enginesound sounds better inside, like it does it in the focus st
Ice_Man is offline   Reply With Quote
Old 10-26-2011, 12:43 PM   #264
madfast
more info about yamaha's involvement with sound in the LF-A. if you ask me, yamaha was brought in to do this more so than mechanical design of the head. everybody knows how to design a high flowing head. but sound? resonance waves and all that good stuff? leave it for the experts, in this case, yamaha.
http://www.yamaha.com/news_release/2009/20091021.html
Old 10-26-2011, 01:54 PM   #265
Tyandriel
Drives: Supra MkIII
a sound actor!? goddamit... the car weīre developing here has one, too. But Iīve never seen it, yet -.-
I donīt like the whole concept. An engine sounds like an engine sounds. My opinion to this is: unnecessary crap. Budget and capacities blown for an utterly pointless device.
Old 10-26-2011, 02:09 PM   #266
v12
v12's Avatar
Drives: none =[[
maybe it is pcv part or it is to big for it
v12 is offline   Reply With Quote
Pictures of Scion FRS in a different environment john FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 05-10-2011 05:46 PM
Report: Toyota FT-86 Sedan Version Coming Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 09-24-2010 10:45 PM
Report: Toyota FT-86 will move up in price and age demographic ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 201 06-02-2010 04:36 AM
Report: Baby Toyota FT-86 also in the works Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 60 05-17-2010 08:41 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 12:36 PM
