Old 12-28-2016, 03:51 PM   #253
Ricks919
Drives: 2014 BRZ brand new!
Originally Posted by Lantana frs View Post
Thank God I don't live anywhere near drift office. I would be penniless.
i will say that he does some damn good work though!!
Ricks919 is offline   Reply With Quote
Old 12-28-2016, 11:41 PM   #254
Lantana frs
Drives: 13 frs red
And he has contributed a lot of knowledge to the community. His tuning threads are incredible.
Lantana frs is offline   Reply With Quote
Old 12-29-2016, 12:33 AM   #255
kitlives
Drives: 2013 Gt86
If youre staying NA, invest in a better Final Drive Gear. That probably be one of the best mods for the money
kitlives is offline   Reply With Quote
The Following 2 Users Say Thank You to kitlives For This Useful Post:
stevesnj (12-29-2016), Teseo (12-29-2016)
Old 12-29-2016, 11:58 AM   #256
stevesnj
stevesnj's Avatar
Keep it simple IMHO;
TRD intake or straight line no bend CAI
EL Headers with fewer bends than stock
port exhaust ports to match header flange tube
final drive change 4.33+
More expensive;
Port the heads, TB and intake horn
internal tranny gearing change
Once you got everything done then get the tune instead of tuning after every single mod. Assuming you got everything done at once
My 2016 Build thread
Old 12-29-2016, 01:56 PM   #257
Lantana frs
Drives: 13 frs red
I wouldn't touch the ports or the intake.
Old 12-29-2016, 02:03 PM   #258
bfrank1972
Drives: 2013 FR-S Argento
I haven't read this whole thread so apologies if already mentioned, but intake manifold spacers like the Crawford billet power blocks have been shown to make a nice useable shift in the power band for a street car. Those in combination with a quality long tube header, shorter FD, and a tuner who really knows what they are doing - IMHO the best and simplest approach for a street car.
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
why? (12-29-2016)
Old 12-29-2016, 02:09 PM   #259
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
other than a drop in filter I agree. Unless the cash is just burning a hole in your pocket for that fancy full intake system.
Old 12-29-2016, 02:28 PM   #260
Teseo
Drives: frs
$600+ without installation
Old 12-29-2016, 06:42 PM   #261
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
not when it comes to e85, those blocks are useless if the car is tuned to e85
Dr. BRZ is offline   Reply With Quote
Old 12-29-2016, 07:07 PM   #262
bfrank1972
Really? That's weird - can you explain the technical reasons why?
I was under the impression that the longer runners shifted the resonant characteristics of the intake so there were stronger pulses earlier in the rev band (making a slightly more use-able torque band), I'd like to know why and E85 tune changes that effect. Maybe has something to do with cam timing?
Old 12-29-2016, 08:27 PM   #263
norcalpb
norcalpb's Avatar
I'm not sure why, but I've heard the blocks are only useful if you're not tuned. There's some dynos with stage 2 with and without blocks and theyre the same.
Old 12-29-2016, 08:38 PM   #264
steve99
On a stock car stock tune The block shift the power band lower in the rpm range and can make a little more peak power as they shift the power band to where the engine is working more efficiently , stock.
Once you get tunes and headers then your usually chamging cam timings and also shifting where the engine is most efficient , this is often higher in the rpm range so the block work against this unless your headers and cam timings are designed to work with the blocks. Same deal with E85 it makes good power through the rpm band but does well over 5500, and the efficiency of engines with the blocks is starting to drop off past that rpm range unless you have made other specific changes to suit the blocks.
So in generall the blocks work well on stock untuned cars and their effectivness drops off as you add other mods
if your going to use blocks then you might be better with something like an ACE CS 400 header which is also designed for low midrange torque
talk to your tuner, see what they recomend
why? (12-30-2016)
Old 12-29-2016, 10:39 PM   #265
Lantana frs
Drives: 13 frs red
I can tell you that the blocks, along with oft tune make a substantial difference in drivablilty. The dreaded torque dip is much less noticeable and there is enough grunt for a 2 litre motor.
Old 12-30-2016, 05:06 AM   #266
kitlives
Drives: 2013 Gt86
I went with Weir Performance fd. $300 for FD and solid Pinion Spacer
The Following User Says Thank You to kitlives For This Useful Post:
Teseo (12-30-2016)
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 09:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 10:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 06:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 10:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 09:53 PM
