#26251 |
AZ FRS 86
I'm at work 2-9 tomorrow. It's closer to you than where I live. If you want to come by my work it's cool. I'm at Big Two Toyota. Just ask for Jeff Sides in the Finance Dept. Or we could meet up sometime.
Sent from ARIZONA86 HQ
@AZFRS86
#26252 |
building life
Drives: Raven Black, 6MT
cool I'll take a drive out there tomorrow. I'll bring my spare & 45$
Sent from somewhere |
#26253 | |
Drives: 2013 Subie BRZ 6MT
#26254 | |
Automotive Connoisseur
Drives: too many cars
There is no fix necessarily for the VVT failures. There has been no update or revision for the parts that are subject to failure. I have been collecting data to determine the actual cause and thus far it points to oil viscosity. These type of valves are VERY sensitive to viscosity on MANY other platforms so it would be no surprise to me that these suffer the same issues. The parts that are failing are the oil control valves in most cases. The ECU then essentially loses control of the cam timing. Since the cams in the FA20 are capable of both advance and retard, there is no real neutral position for them when they fail. They will and do literally swing from basically full retard to full advance as the ECU tries to get control of them. They can swing throughout their articulation quite a bit and never hit the valves but that is not to say it hasn't in your case. If something more catastrophic has happened such as lets say a blown headgasket, cracked head, cracked sylinder, etc etc. that could explain your oil eruption you had along with the milky oil too. Lots of crank case pressure can build up in those scenarios. Loss of oil pressure can also cause all those codes you are seeing so if you have an oil pressure guage you can hook up I would while you do a startup. Also I am curious why you think there may be a possibility that you sucked up water? Did you run through any big puddles or anything? I mean obviously you are running a rear mount which is more susceptible to water ingestion but I can't imagine you would have driven through anything that would have cause THAT much ingestion..... Either way it sucks. I highly doubt the dealer will cover your engine but I have seen crazier warranty before so who knows. Regardless I am interested to see what happened to your engine if you do determine what the failure was.
LSx Powered 86/ASE Master Certified Automotive Technician
#26255 |
Drives: 2013 FRS
Just a heads up @Cross. In order to get back your money on that extended warranty you will have to go to the dealer location and sign some paperwork to make this happen. It Will go towards your loan. I did this myself
A zen master once told me "Do the opposite of everything I say", so I didn't.
#26256 |
Weendog
Drives: 2014 Scion FR-S
#26257 |
It's the Mad Cow
Alright I sent it in to the Dealer just to see I told Peter the service manager up front what was going on and what I found I still expect to be denied but I will have an answer on the motor so if I choose to sell it as a builder I can give a detailed answer.
They did agree to refund my extended warranty, and it seems a few in my other thread are pushing me towards putting in the LS1 sitting here... if so I guess that means I am selling my turbo setup, injectors and other items... we shall see. I don't want to run into this problem again and it looks like there is no part replacement that can stop it from happening again...
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#26258 |
Good luck man hope everything turns out ok.
Sent from my SCH-I545 using Tapatalk 2 |
#26259 | |
Fat on Corn Syrup
I know you already dropped it at the dealer, but is it possible the coolant used to cool the turbo somehow got sucked into the intake? I don't know how the cooling lines or jackets are routed in that setup... Good luck man. |
#26260 |
That's an oiless coolantless turbo setup.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#26261 | |
It's the Mad Cow
Honestly I think this is just going to turn into they fix it or I seem all of it and LS swap it
#26262 |
Fuck it v8 it anyway! That's what I wanted to do originally. Lol
#26263 |
AZ FRS 86
@AZFRS86
| Tags |
| arizona, fr-s, mesa, phoenix, scion, tucson, we need a subforum |
| Arizona Bill 'could' criminalize Internet Trolls | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 12-30-2013 02:54 PM |
| Accessories page for Canadian BRZ owners | percyng | CANADA | 1 | 06-15-2012 07:27 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
