Old 06-02-2017, 02:05 PM   #2577
ssworks
Drives: blue
Originally Posted by alxtheoreo View Post
Anytime
The key word is "unmarried". You'll need to be certain the previous owner unmarried OFT from their car. Also make make sure they have the OBD2 cable, plus the mini USB cable so you can update the OTS maps.
Sent from my SM-G930V using Tapatalk
Thank you for that, besides taking their word at face value, is there a visual setting that they show you on the tablet that shows its unmarried?
ssworks is offline   Reply With Quote
Old 06-02-2017, 02:10 PM   #2578
alxtheoreo
alxtheoreo's Avatar
Yes there is. I can't think of which screen it is (I'm also stuck at work), yet hopefully another person can chime in.
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 06-02-2017, 02:18 PM   #2579
ssworks
Drives: blue
Thats fine, I will just do some research once i know there is a way to tell. lol Must be a pic or thread on the topic somewhere.
Old 06-02-2017, 03:02 PM   #2580
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
should look like this when connected to the pc
http://www.ft86club.com/forums/showthread.php?t=103825
murdoc is offline   Reply With Quote
Old 06-03-2017, 01:29 AM   #2581
n0thing
Drives: Subaru BRZ
had uel+op+cbe, already running oft stg2 uel 93
just installed catless fp w/ resonator, i believe the same map applies. do i have to reflash/reinitialize anything or will the ecu relearns over time?
thanks
n0thing is offline   Reply With Quote
Old 06-03-2017, 07:41 AM   #2582
alxtheoreo
alxtheoreo's Avatar
thanks
You're correct. The same map applies & you don't need to reflash.
I recommend crusing at highway speeds for about 100 miles with the cruise control set, so the ECU will learn faster. Otherwise, it'll take about a tank of the same gas with normal around town driving.
Old 06-19-2017, 08:02 PM   #2583
n0thing
Drives: Subaru BRZ
thanks
ended up installing catless fp w/out resonator, anyhow...
along with a k&n filter, is it worth the jump to ecutek and have it custom tuned if i stay NA? never dyno'd it so idk where it currently sits, and idk how much ecutek will gain.
Old 06-19-2017, 09:22 PM   #2584
steve99
You can get custom tunes with oft as well as ecutek.
Theoreticly on an NA car you will get same results with oft or ecutek with a conpetent tuner.
Cusrom tuning on NA cars often yeilds very little gains.
Just log you tune check the fueling mainly, if your fuel trims are fairly low 5% anc you afr and commanded afr are close duribg wot, then custom runing is going to yeild you very little if your on 93 fuel.
Old 07-10-2017, 04:58 AM   #2585
macca86
Drives: 2013 86
Hi all,
New to the forum thing and am not here for a good reason sadly.. I received an open flash tablet today and plugged it in asap. I chose the stage 1 stock tune and followed the steps to the tee, and got to the last part where it says turn off ignition and then turn engine on and let idle for 45 secs.. however the car ticked over for 1 sec and gave up. I tried to start it again and got no response, so naturally i sh*t my pants and reflashed back to the original file and tried to start it again and the car didnt start.. i tried to start it a couple of times and the battery seemed to be getting flat as the air con wouldnt turn on nor could i lock the car via key fob.
Ive emailed open flash but i live in australia so im not expecting a reply for awhile, can anyone give me some troubleshooting advice!? Stressing hardcore.
Cheers
Mac
macca86 is offline   Reply With Quote
Old 07-10-2017, 07:43 AM   #2586
steve99
Originally Posted by macca86 View Post
Hi all,
Cheers
Mac
If the oft communicated with car ecu its likely the flash was sucessfull and your ecu is fine
Id say you may have a battery problem. Put a charger on battery and see if the car will start.
Its not good to flash cars with low or suspect batterys but i think your ok.
Have a read of link below
If your ecu flash failed the car would not even try to start, and if ecu was bricked the oft would complain about being unable to talk to ecu.
I think its jist flat battery hopefully if your a 2013 car on original battery it was probavly on its last legs
http://www.ft86club.com/forums/showthread.php?t=99171
Old 07-10-2017, 07:52 AM   #2587
macca86
Drives: 2013 86
Of your ecu flash failed car would not even try to start and if ecu was bricked the oft would complain about being unable to talk to ecu.
Hey mate,
Really helpful, thank you! Im gonna chuck a charger on it tomorrow and will get back to you. Fingers crossed.
Mac
Old 07-19-2017, 05:00 AM   #2588
skogs
Drives: GT86 2013
Any chance there will be a 93 octane map for EU-cars like there is for US?
For my particular car (ZA1J700I) there is only one Stg2 UEL-map available. I'm guessing its for 91, i always fill up with 93 regardless, and it would be nice to unlock the extra power.
skogs is offline   Reply With Quote
Old 07-31-2017, 09:21 PM   #2589
Jahris
Drives: 2013 Scion FRS
Wut up! I just replaced my dead battery with new and reglashed my EL E85 tune on the OFT.Now my a/c don't work and my ABS/Traction Control light is on...any thoughts would be kindly appreciated!
Jahris is offline   Reply With Quote
Old 07-31-2017, 09:41 PM   #2590
phrosty
Did you let the battery charge all the way before you flashed?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
